Firewall on a 6th Gen Maxima
Old Jan 17, 2005 | 05:21 PM
MaximaSE2005's Avatar
Has anyone run a 8 gauge or lower power wire through the firewall of a 6th gen max? If so, did you need to drill a hole or is there an opening somewhere in the firewall for the wire to go through?
Thanks.
Old Jan 17, 2005 | 10:51 PM
kpr10is's Avatar
If you have an automatic, then look where the clutch plate would be if it were a stick shift, sometimes the firewall will have a bulge or indent or some way for you to tell that it is the right spot, where the clutch would have gone through the firewall. Anyway, thats always a safe place to drill. I havent worked on one personally so Im not sure if there is a factory grommet to use, but since it is only 8 gauge...if you see a grommet you should be able to fit it through.
Kevin
Old Jan 18, 2005 | 03:39 AM
Thanks Kevin. It's an automatic.
Lakersallday24
Nov 7, 2024 07:31 PM
CRizz
41
Jun 7, 2021 05:42 AM
morteljc
Oct 19, 2015 10:47 AM
schmellyfart
Sep 25, 2015 04:47 PM
