Newb: Help installing amp
Old Jan 19, 2005 | 06:04 PM
monknster's Avatar
Trying to install my amp rockford fosgate P8002, having hard time running the power wire from the battery somebody please help me I've been trying to do this for past 3 hours and result NOTHING.
Old Jan 19, 2005 | 06:38 PM
jzq's Avatar
jzq
Need more details. whats ur prob? u cant run the wire thru the firewall or u get no power?
Old Jan 19, 2005 | 07:13 PM
2 Da Max's Avatar
do you have an inline fuse?
Old Jan 19, 2005 | 08:08 PM
monknster's Avatar
cant find the hole through the fender wall/ cant find a hole period in the engine bay
Old Jan 19, 2005 | 08:29 PM
jzq's Avatar
jzq
With my car, which is a 99, I just followed one of the battery cables. One of them leads to the fender wall I believe. You can definately find it if you jack up your car, take off the tires, and pop off the fender well cover. I sort of had problems opening the well cover and broke a few screws but it can be replaced at a tire specialist (e.g. NTB). The best tool to use here would be one of those trim removal tools. There's also a few phillips screws on the edges. Once open you will find the hole that leads from the engine bay and a battery cable running through the hole leading to a rubber grommet. You're gonna have to cut a hole through the grommet and poke your amp power cable through it. I just installed mines last week and it works fine. Hope that helps. PM me if you have ne more questions.
Old Jan 19, 2005 | 09:32 PM
monknster's Avatar
Oh man thank you ... You saved my day
Old Jan 19, 2005 | 09:51 PM
AscendantMax's Avatar
I wish I took the time to look for a grommet/openings in my 3rd gen before drilling a hole through the firewall
MaxLife17
Jun 27, 2019 01:37 PM
2kmaximel
Sep 16, 2015 03:19 PM
popdedop
Sep 11, 2015 11:17 AM
