Static On Radio When Defrost On
Old Jan 19, 2005 | 08:32 PM
yeshivishmaxima's Avatar
HI GUYS, I JUST REALIZED THAT I GET STATIC ON THE RADIO AM/FM WHENEVER I TURN ON THE REAR DEFROST. HAS ANYONE HAD THIS BEFORE?
Old Jan 19, 2005 | 09:53 PM
acj's Avatar
acj
I've never actually seen this before, but I'd say it's possible. I'm guessing it could be something in the wiring...
Do you have the stock Bose system or aftermarket?
Old Jan 19, 2005 | 10:40 PM
SPiG's Avatar
SomePsychoGuy
Official Caps Lock Post
Thank you.
Old Jan 19, 2005 | 10:45 PM
chenzarino's Avatar
Maximas have a weird *** "double diversity" or some crap like that antenna, where it has the regular antenna and one incorporated into the rear window. If you're on a stock radio, theres probably bad wiring ot that antenna. Get an aftermarket unit, thye don't use the second antenna.
Old Jan 20, 2005 | 12:45 AM
SPiG's Avatar
SomePsychoGuy
Ok sorry. I had to do that. Now I have the "Official Caps Lock Post" to link to.
You have to get an adapter to adapt it the normal antenna interface?. I found out the hard way that (at least in my car) the radio will not function if there is no antenna plugged in.
Here is what I could find:
http://forums.maxima.org/showthread....efroster+radio
Old Jan 20, 2005 | 01:43 AM
chenzarino's Avatar
If you go aftermarket headunit yes you have to get an adapter. If you're going aftermarket antenna with stock radio, you need help.
Old Jan 20, 2005 | 05:14 AM
i have a cd,radio,tape clarion headunit from a 2001 altima, i put an antenna adpter to covert the 2 prong wiring from car to a 1 prong soi fit the altimas HU. an i just noticed that when the rear defrost is on i get static
gavin68
Sep 18, 2021 12:36 PM
chisam14
Nov 6, 2018 08:56 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
