Ground cable lengths.
Old Jan 21, 2005 | 10:09 AM
jzq's Avatar
jzq
Ground cable lengths. Need help please!!!
I want to use a distribution block to distribute my ground wires. I am hooking up two 8 gauge wires from my amps to the block and a 4 gauge connected to a ground terminal. What is the maximum suggested length for each wire?
(e.g. 4 gauge: ?in. 8 gauge: ?in.)
Old Jan 21, 2005 | 01:52 PM
Micah95GLE's Avatar
You are using 2 power cables for the amp?
Old Jan 21, 2005 | 01:57 PM
jzq's Avatar
jzq
I have 2 amps. one for sub and one for speaker.
Old Jan 24, 2005 | 07:11 PM
alpimax99's Avatar
within 18 in.
Old Jan 24, 2005 | 07:23 PM
AscendantMax's Avatar
as short as you can make it.
Old Jan 24, 2005 | 07:55 PM
2 Da Max's Avatar
dam mines 2 and a half feet
Old Jan 24, 2005 | 09:17 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Why even use a distirbution block? Unless its for cosmetics its really not needed. Like posted above...as short as possible without major tension.
--Don
Old Jan 24, 2005 | 10:12 PM
jzq's Avatar
jzq
So a ground distribution block would only weaken my performance?
Old Jan 24, 2005 | 10:22 PM
why not just bolt all the grounds to a common grounding point? there will be less resistance that way than going through a distibution block.
Old Jan 24, 2005 | 10:23 PM
kpr10is's Avatar
It wouldnt weaken or strengthen it, Don was just saying why waste your money because it will be the same either way, whether you use one or not.
-Kevin
Old Jan 25, 2005 | 05:03 AM
Pearl96Max's Avatar
-Kevin
Exactly All grounds can just go to the same point...
Old Jan 25, 2005 | 07:46 AM
ashmrx's Avatar
Last note to you is the shorter the less ground noise and keep it away from RCA cables.
Old Jan 25, 2005 | 08:26 AM
2 Da Max's Avatar
rcas is audio signals and ground and power are ac siganls. there will be no noises if ran together
Old Jan 25, 2005 | 09:29 AM
ashmrx's Avatar
Yes you will produce noise if wires cross. Physics 101.....What happens if electrons cross a magnetic field @ 90 degrees == voltage. How is magnetic field produced..= flow of electrons.
so now how do you pick up radio waves in your car driving? Metal rod sticking up from your hood on your car crossing radio waves in the air. Please take it from me A MRI Technologist that knows what and/or is noise. So don't cross wires ......peace...
.......Patriots Rule.....
Old Jan 25, 2005 | 09:46 AM
Pearl96Max's Avatar
OK then heres basic common sense 101...
Battery is grounded to chassis, battery goes to amp power, ground from amp to chassis. What do these all have in common? ALL GROUNDED. The chassis is a ground, regardless where you run RCAs it still runs with the power source. Running signal and power paths seperately is very old MYTH. Nothing more.
--Don
Old Jan 25, 2005 | 10:16 AM
ashmrx's Avatar
Yes I know things are grounded Noise has nothing to do w/grounding. The Common Sense is when any time a flow a voltage crosses w/other voltage it will change the magnectic dipoles of an electron regradless if it's just signal or ac power. It has nothing to do with all being grounded. All grounding does it redirects electrons so you will not get jolted. All electrons need a path to flow.
Old Jan 25, 2005 | 10:28 AM
friendhasmax's Avatar
FOOL.....you cannot get noise from a DC power system crossing AC signals. thats from Electromagnetics which im sure you would have had in your school.
and that is not the reason for radio reception. the only thing a moving car antanna would do might be a doppler shift of the frequencies but the car is much too slow for that. what are you smoking man? so tell me where you describe noise in ur post? as an electrical engineer, i dont see it =)
Old Jan 25, 2005 | 10:31 AM
Pearl96Max's Avatar
I figured Id let ya have fun before I replied here again
Old Jan 25, 2005 | 10:34 AM
excuse me, but you are full of BULL**** info. sounds like you never took a physics class before. you obviously don't know what "ground" means, and im not about to explain it to you. since when does voltage flow? electrons don't have poles either. noise is the introduction of unwanted AC voltage on your AC signal. DC cannot cause this. if y ou want to be technical, the whole chassis of a vehicle would then be a huge antenna for noise if you were correct, which you aren't. sounds like someone better hit the books some more =)
thanks brotha
i know i can count on you
Old Jan 25, 2005 | 10:40 AM
Pearl96Max's Avatar
ash....anything to comment? Or searching books for something?
Old Jan 25, 2005 | 10:43 AM
he's busy performing MRI's, or looking for the power switch.
Old Jan 25, 2005 | 10:47 AM
Pearl96Max's Avatar
LMFAO
...looking for the switch buahahaha
Old Jan 25, 2005 | 10:57 AM
ashmrx's Avatar
Fool... now thats funny...What do you think Electromagnetics is. A change in any voltage will produce a change of electrons from positve to negative. Just because your not able to hear noise that does not mean its' not there. Now if you amp that up then you will hear it. All noise is a change of electrons from + to -. So Next.
Old Jan 25, 2005 | 11:00 AM
ashmrx's Avatar
Sorry took time I'm making lots of noise w/my dc Motor
Old Jan 25, 2005 | 11:05 AM
lmao, don are you reading this? so now we are discussing electrons and positrons? lol since when did positrons come into play? not only do you perform MRI's, but you're also a particle physicist as well? you just made yourself look even more dumb than you first appeared. you still haven't the slightest idea what noise is man. noise is the superposition of an unwanted ac signal onto any other signal. the discussion will end here. please stop making yourself look stupid.
Old Jan 25, 2005 | 12:54 PM
Maximeltman's Avatar
anyone know where the power line from battery connects to the alternator??
Old Jan 25, 2005 | 01:48 PM
always did enjoy reading friendhasmax's detailed posts
Old Jan 25, 2005 | 02:19 PM
kpr10is's Avatar
+123.........10 characters
Old Jan 25, 2005 | 05:17 PM
i'm sure............
Old Jan 25, 2005 | 05:26 PM
Maxima Dan's Avatar
WTF?!
Just stop...please
Old Jan 25, 2005 | 08:41 PM
2 Da Max's Avatar
friendhasmax whatup!, neways the kicker well, uhm... lets just say it doesnt Kick anymore
posting new setup tommorow!
Old Jan 25, 2005 | 08:57 PM
Pearl96Max's Avatar
Thats why I IMed and linked him. I thought I would give some laughter to his day
Old Jan 25, 2005 | 09:35 PM
You're not going to have all the fun eh ? Best part of all those technical posts (some are way over my head ) is that I pick up a few things here and there that I didn't know before
Old Jan 25, 2005 | 10:37 PM
2 Da Max's Avatar
yea ^^^^ i used to believe that rca and power issue until friendhasmax cleared that up.
Old Jan 26, 2005 | 08:02 AM
Pearl96Max's Avatar
My fun is when people get out of hand and I give them a free vacation. :biggrin:
Old Jan 26, 2005 | 09:15 AM
slickrick's Avatar
generous guy aren't ya?
Old Jan 26, 2005 | 10:28 AM
Pearl96Max's Avatar
I try
BTW..PM I may have some DA stuff for ya down there
gigabyte
Jan 6, 2017 06:05 PM
sliptap
Sep 30, 2015 05:57 AM
pktaske
Sep 4, 2015 08:40 AM
