Bose system completely out
Old Jan 22, 2005 | 04:15 PM
JC96max's Avatar
I got a 96 max with a bose system, panasonic head unit and an alpine sub. Today while I was on the highway, all of my bose speakers stopped working but my sub was still putting out sound. Has this happened to anybody else?
Old Jan 23, 2005 | 03:44 PM
elchino's Avatar
Same thing just happened to me this weekend, but I have an 02 with the Bose system and JVC head. The sound is actually in and out while I'm driving; more out than in.
I'm thinking the Bose amp is out; I'm not sure how the system is set up on the 96. I have to plug up my sub and amp and if they put out some sound like yours, then at least I know it's not the head unit. (It's still getting power right now)
This afternoon I even chased wires behind the head unit and didn't find anything. The wiring to the bose amp looks good. But it looks like this'll be a time consuming process.
If one speaker was grounding out, do you think it would cause the other ones to cut out?
Old Jan 23, 2005 | 04:21 PM
2 Da Max's Avatar
check fuse...
Old Jan 24, 2005 | 09:25 AM
JC96max's Avatar
i'm pretty car illiterate, i looked for fuses that said speakers under the hood and under the steering wheel but saw nothing that said speakers. Is there another place I could look?
This morning I turned on my radio to find that it worked for about 5 minutes but then cut out again.
Old Jan 24, 2005 | 12:40 PM
Pearl96Max's Avatar
I tend to get a bit irritable
How is the HU connected? Direct wire or through an 'adaptor'?
--Don
Old Jan 24, 2005 | 02:37 PM
JC96max's Avatar
the headunit is connected through an adapter
Old Jan 24, 2005 | 06:17 PM
ashmrx's Avatar
It's not your car or wires Bose systems are the worst buy a set of new speakers. Ask the pros they'll tell that same ......peace....Patriots Rule.....
Old Jan 24, 2005 | 06:53 PM
BLUEMAX01SE's Avatar
It's Going To Be The Bose Adapter That Connects The Speakers And Their Amp To Run Thru The Headunit! For Example You Should Probably Have A Periphial Or Sumthin Like That, ( That's The Namebrand Of The Bose Adapter ) Once That Goes Out You Will Not Get Sound From Your Bose Speakers. It's Very Unlikely That All Of Your Bose Speakers Have Blown At The Same Time, So The Good News Is All You Should Have To Do Is Swap Out The Adapter With A New One! I Have Had 2 Maxes And Have Always Kept The Bose Speakers Inside , They Sound Awesome. I Have An Alpine Cd Deck And Polm Momo Subs Runnin Off A Hifonics Brutus 1000 And The Combo Of The Subs And Stock Bose Speakers Inside Is Actually A Very Very Great Sound Quality! The Bose Can Produce Those Great Mids And Highs Especially With The Tweeters In The Max! Do Not Swap Out The Bose Speakers, Those Are More Than Likely Not Blown, Good Luck With Changing The Bose Adapter, Like I Said I Think The Name Brand Of The Adapter Is Periphial ! It's Like $20 At Circuit City!
Old Jan 25, 2005 | 07:20 AM
JC96max's Avatar
ok cool. I'm pretty sure I have a peripheral adaptor but I dont remember because it's been a few months since i took it apart. Will I have to routinely replace that adaptor?
Old Jan 25, 2005 | 08:44 AM
Jc96, You Should Not Have To Replace It Routinely , I Have Had My Periphial Adaptor For About 4yrs Now And It Has Been Good For Me, Knock On Wood Now That I Mention It! You May Have Hit A Bump That Could Have Caused Wires To Come Loose Or If It Is Not Secure Behind The Dash, It May Have Just Taken A Beating! I Used 3m Double Sided Tape To Secure Mine Behind The Dash, And It Has Been Good Since, Even With The Ac/heat That Is Behind The Dash, Tape Has Not Come Undone! Good Luck!
Old Jan 25, 2005 | 02:14 PM
elchino's Avatar
i'm gonna spend this weekend chasing down wires, starting behind the head unit. I hate this cause there are so many and all the connections (external splices) looked fine. let you know if i find something
Old Feb 3, 2005 | 03:32 PM
JC96max's Avatar
I finally went through and made sure all of the wires were connected and they all were. There were two connections where the metal part was showing and the ground wire had some of the wire outside of the rubber so I put tape around it. Everything seems to be working fine now. Maybe the metal parts were touching that werent supposed to be touching? I dont know, but if it works it works.
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
220k+ A32
Sep 11, 2015 02:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
