constant 12 volt source
Old Jan 24, 2005 | 03:57 PM
hollaatchaboi's Avatar
what is another constant 12 volt source other than the ciggarette lighter? How many things can i wire to the cigg lighter wire if i change the fuse?
Old Jan 24, 2005 | 04:18 PM
djfrestyl's Avatar
Suspension Yoda
cigarette lighter isnt constant - it turns off when the car does. what are u wiring to it and - dont up the fuse, find a higher current.
Old Jan 24, 2005 | 06:52 PM
KPSPE's Avatar
You should probably consider running another wire directly to the battery. Tapping into existing wiring will often lead to overloads and blown fuses if not done correctly.
Old Jan 24, 2005 | 09:34 PM
kpr10is's Avatar
The ignition harness has a good 30 amp constant wire you can tap right into if you take the panel off under the steering column. On a 98, the constant wires there should be white with a red stripe, or white with a purple stripe, and it will be a 12 gauge wire coming right off the steering column area.
-Kevin
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
msellas
Sep 23, 2015 09:16 PM
lrb6805
Sep 17, 2015 04:49 PM
jfl330
Sep 4, 2015 01:44 PM
