Disconnecting Alarm
Old Jan 24, 2005 | 05:10 PM
RockinTheDecks's Avatar
Disconnecting Alarm
I know someone said you disconnect the black box under the stereo, but I dunno. There's a small black box that sits on top of a silver box. Each has 2 or 3 harnesses coming into it, and I don't want to disconnect any of it until I'm sure of what I'm doing.
Anyone know exactly what box and what harness I need to disconnect?
Old Jan 24, 2005 | 05:32 PM
Anyone? I know it's only been 10 mins since my post, but I've got the consol out already and I'd like to find out before putting it back on to save myself the time of removing it again. Thanks!
Old Jan 24, 2005 | 08:23 PM
nobody????
Old Jan 24, 2005 | 08:35 PM
well, since this has been moved, this is on a 4th gen factory alarm.
Old Jan 24, 2005 | 08:51 PM
Pearl96Max's Avatar
I tend to get a bit irritable
What is it exactly that you trying to ultimately do? Why are you trying to disconnect the factory Keyless entry?
--Don
Old Jan 24, 2005 | 08:53 PM
Because I will be getting an aftermarket one in the next few days
I understand the reluctance of people telling me how to do it for security reasons, but cans omeone at least tell me what exactly will set off the alarm?
Basically, I didn't even know I had one until the other day when it started going off for no apparant reason. I was messing with some stuff while the battery was disconnected, and when I reconnected it, it went off. I would at least like to know what I may have done to set it off.
Old Jan 24, 2005 | 08:54 PM
Also, it's not a keyless entry system either. Or if it is, I don't have the remote.
Old Jan 24, 2005 | 09:00 PM
Pearl96Max's Avatar
When you lock the doors with either the remote,key in door or lock switch on the door it sets the factory 'alarm'. If you open the trunk,door(s) or hood it will set it off. There is absolutely no need to locate/remove it for a new alarm.
--Don
Old Jan 24, 2005 | 09:25 PM
kpr10is's Avatar
+1 on the fact that there is no need to disconnect the factory alarm. The new one will have 'factory arm' and 'factory disarm' outputs on it.
Im confused: So the new one you are putting in is just an alarm without keyless entry? Even those come with remotes. What is the point of putting it in...as Don said our factory alarm is good enough that all you are basically doing is adding a shock sensor and a starter kill...and you have a 99 so you have a chip in your key anyway. Might as well save your money for a better alarm with a lot more features.
-Kevin
Old Jan 24, 2005 | 10:04 PM
-Kevin
The aftermarket one I get will have keyless and possibly a remote starter...I meant the factory one doesn't have keyless entry
Old Jan 24, 2005 | 10:15 PM
kpr10is's Avatar
Ahh so you lost the factory remote? I gotcha.
Either way, you dont need to disconnect the factory alarm...when the new one goes in they should hook up the factory arm and factory disarm and make it all work
Kevin
Old Jan 24, 2005 | 11:24 PM
Well, I got the car used a year ago, and it didn't come with any remotes...Is there any way to just get a new remote for the existing setup?
Old Jan 24, 2005 | 11:37 PM
kpr10is's Avatar
You can only get a new factory remote from the dealer or ebay, either way it has to be programmed to the car and it isnt cheap.
Old Jan 25, 2005 | 08:40 AM
ok, thanks
gigabyte
Jan 6, 2017 06:05 PM
doctorpullit
Mar 29, 2016 11:08 AM
maxima297
Sep 30, 2015 03:32 PM
AaronL
Sep 23, 2015 03:34 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
