so my antenna snapped off at the car wash today..
well you can go about this in 2 ways. im gonna get a antenna to isntall inside so i cna shave off the outside antenna.. cause i hat ehte antenna going up down etc crap.. or get a enw replacement from pepboys or junkyard.. or u can have mine.. depending on when i replace it hehehe.
and yea it seems like a diy... i mean it depends on hwo worried u are about it.. but i think u can manage... and what are u gonna do rahter whats the worst u can do... break it..?
This is a very easy job.
1. Turn off radio.
2. Go to rear of car use "antenna key" or a pair of needle nose pilars and unscrew the silver ring.
3. Have someone turn on the radio as you pull upward gently (not to brake the cable) on the mast.
4. Verify the mast cable is not broken. If it is, you have to take the whole motor and everything out and take it apart to get all the pieces out. If its not broken then put in the replacement mast (that you bought from the dealer/auto zone/etc) back in.
5. Have someone turn off the radio again while you shove the cable back into the motor until it catches. Once it catches guide it back in.
6. Put the silver ring back on and tighten it down.
7. Finally, turn on the radio to verify that the mast goes up all the way.
1. Turn off radio.
Lakersallday24
06-16-2019 01:35 AM
scarletsosa
08-17-2015 09:09 PM
altome15
08-10-2015 07:05 PM
