battery for system
Old Feb 16, 2005 | 07:33 PM
ghostridden's Avatar
battery for system
do i need to buy a battery for just my subs?? it seems to be straining my alternator quite a bit right now and i was wondering if a batter would make it better
Old Feb 16, 2005 | 08:59 PM
BRINKLEY's Avatar
I can't imagine subs pulling that much from your battery. Are you running an amp or just the subs?
Old Feb 16, 2005 | 11:23 PM
BLUEMAX01SE's Avatar
just replace your current battery with a yellow top and you should be ok- no dimming - that's what i did for my system - i have about 1000watts so im running 4 ga cable from the amp to the yellow top optima battery - size is 34/78 series yellow top - good luck
Old Feb 17, 2005 | 06:11 AM
yea i have 2 10 punch stage 2's on a 500 watt fosgate amp, bad dimming and not to mention that when i'm stopped and start to take off with the stereo blaring, i have to basically floor it cause my rpms are really low because of the stereo, how much does a yellow top optima cost?? isn't it like 150?
Old Feb 17, 2005 | 06:33 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Have your alternator checked.
--Don
Old Feb 17, 2005 | 06:18 PM
yea thats what i'm thinking, cause its nver been replaced, and its got 187k on the motor, if i turn my stereo way up it stutters during acceleration, it tends to cut off (the subs) which i think is due to starving the alternator
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
MichMaxFan
Sep 30, 2015 09:18 AM
