equalizers...AudiControl, Zapco or CDT???
Okay, youve sold me on the CDT components, but what about an equalizer? Everyone says theirs are the greatest, but which one is better? CDT offers one for thier speakers, but im not really sure its an equalizer. Then of course, theres the AudioControl (www.audiocontrol.com) stuff, but no one seems to know much about it. And im going with the Zapco amp (360.4) and the guys at Zapco said the sp4-sl equalizer would work great. Any comments???
Originally Posted by 2 Da Max
someone on the org told me eqs are bandaids to a bad sysem?
Well, everywhere Ive read, its important to set up the system ona equalizer to get the best "realistic" sound. If its set up right, you get the feeling that there is a "stage" right in front of you and you can visualize where each instrument or voice is coming from.
And I know equalizers are NOT bandaids. One of the performance car audio mags had a photo of a Benz that had like 4 Helix amps set up and an AudioControl EQ in the trunk, so if Helix amps are part of a bad system, then hell, what makes a good one???
I have an AudioControl EQ 4 channel and let me tell you, it DOES make a difference in sound. You are to set it once to the acoustics of your interior, and that's it. Maybe, that is why it's a seperate unit to be mounted in the trunk, so that you don't have to keep playing with frequencies. Check my homepage for pics.
An automotive environment suffers from many annoyances such as cancellations and reflections, not considering the differences in drivers and its effect on stock OEM locations. I do agree however that it should only be used to boost or cut only particular frequencies that need it, not the improper use of boost across all bands.
Aftermarket EQ's main benefit IMO, is that they are high voltage preamps. The boost in signal strength and high voltage signal to the amplifiers alone allows for more headroom and keeping your amps gains lower to achieve their maximum power.
I agree with Manny. It's nearly impossible to achieve a flat in car response without an EQ. However, I also agree with the post about buying an aftermarket HU. I would definately suggest doing that first since most HUs sold these days have some sort of EQ built in already.
If you do still decide you need an EQ I'd lean toward whatever you can find a good deal on off ebay. Personally, I've always used Audiocontrol and I've never been dissapointed with their products but there are plenty of other good options out there.
Okay, since I can tell you know what youre talking about, Lets say I get an Eclipse 2454 HU and a Zapco 360.4 amp (with optional Symbilink) and some CDT ES-600's & ES-620's. Will I still benefit from an EQ? I really like the Eclipse HU, but dont like the fact that its not XM ready. Is there one of similar quality as the Eclipse that is XM ready without sacrificing features? Also, what AudioControl EQ would work best for my setup??/
thanks!!
Haven't really studied up on XM capable HUs, but I believe Pioneer Premier and Alpine make some.
Look for a HU with a 5 band parametric EQ and you'll be good. Unless you are really looking for perfection and are willing to take the time and spend the money on true 1/3 octave eqs, I really wouldn't bother with anything else.
thanks!!
thanks!!
-_Don
Originally Posted by Pearl96Max
The discontinued 2454 has a decent EQ already built in. The newer/current 5435 has the same EQ and with a bit more on the preout side. Whichever one you go with they will do the job, unless like Maxima Dan said you spend the money for a higher end EQ. Some will say any will work, not usually the case as cheaper units will just add more noise, rather then help the system.
-_Don
-_Don
thanks guys!!!!!
So is the Eclipse classified as a cheaper unit that will just add noise?
Okay what do you think of this setup. I have a Alpine 7977 headunit with a Alpine 5755 sound processor/eq. I am considering get rid of the soound processor so that i can drop the cd player down to the bottom din slot and put my 5.6 monitor in where both headunits currently reside. But my curiosity is on what you guys think about my combo?
How does this help answer my original question?!?!?!?
dont hate on alpine becuase of the other thread. they do make quality products, its just not their fault there are better brands out there for cheaper/same cost.
anyway since were on the topic of eq's, a friend of mine claimed his friend got an eq for his car and made it sound 10x better and alot louder. is this feasible or did he not know how to use his radios eq and just turned up all the frequencies ala pimp my ride to make it louder/more distortion?
[QUOTE=slickrick]dont hate on alpine QUOTE]
Wasnt hatin on Alpine, its just whenever I ask about quality, no one ever says anything about Alpine. And, like you said there are better products out there for the same price (most of the time), and I know that price is a big factor, but if youre already spending a few hundred (or thousand) dollars on a system, why not just do it right the first time? (Just my opinion here)
anyway since were on the topic of eq's, a friend of mine claimed his friend got an eq for his car and made it sound 10x better and alot louder. is this feasible or did he not know how to use his radios eq and just turned up all the frequencies ala pimp my ride to make it louder/more distortion?Thread
NYCe MaXiMa
Oct 14, 2003 07:15 AM
max'n out
Jun 18, 2002 08:16 PM
max'n out
Jun 17, 2002 06:14 AM
I was expecting an answer. But oh well, at least I know im on the right track
