Headlights Dim with Bass (I know...Noob)
Old Mar 7, 2005 | 06:04 PM
ja1997max's Avatar
Any help to solve this would be appreciated...I am sure this has been addressed however I haven't been on the .org for a while and cannot search, and have no clue about car audio.
Do I need a new battery (i.e. better/stronger)?
Is it b/c of my setup: stock HU, KAC-929 amp, 2 10" subs?
What is the danger/negatives other then dimming lights if not rectified?
Again thanks for any help, it is much appreciated,
Jordan
Old Mar 7, 2005 | 06:11 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
they will tell you to upgrade the ground to the altenator and around the engine bay. look for a write up on ground kit. you can get a capacitor for your system also. check ebay, type 1 farad.
Old Mar 7, 2005 | 07:47 PM
LoMaximA96's Avatar
don't waste your money on a cap spend the money on a good deep cycle battery, what is the current draw from your amp?
Old Mar 7, 2005 | 08:56 PM
Playero's Avatar
Sanduguero
and someone like me will tell you just get an alternator if you got the money.
Old Mar 8, 2005 | 10:59 AM
03SE2HEAR's Avatar
1) Get a good battery, not a Die Hard piece of poop. A deep cycle battery is nice but not made to handle more than a trickle charge, not a good battery for starting applications.
2) Run a decent power and ground wire off of the amp.
3) Somewhere in the org is a thread on "the big 3", look for it.
4) Depending on how much power you're running, a capacitor will help.
If you're constantly dropping voltage and the lights are dimming, then your other components that run on 12V are also getting starved for Voltage. The more consistant your Voltage is, the more efficient the electrical components will be (ie:amps, etc)
5) Upgrade your ground wire to the battery to the same gauge wire you have going to the amp on the positive side...
Old Mar 8, 2005 | 11:00 AM
2 Da Max's Avatar
just get bigger guage of wire it should solve the problem
gavin68
Sep 18, 2021 12:36 PM
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
