Power antenna trigger wire
Old Mar 8, 2005 | 09:41 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
Does anyone know which wire on the harness on the back of the BOSE radio lowers the antenna? Is it a low (0v) for antenna lowered and high (12V) for antenna up?
Old May 11, 2005 | 02:09 PM
Dan's Avatar
Dan
bump it up
Old Aug 12, 2006 | 06:52 PM
craigl33's Avatar
yearly bump. i wanna know the answer too.
Old Sep 3, 2006 | 07:22 PM
google9's Avatar
please anyone ?
Old Sep 3, 2006 | 07:25 PM
djfrestyl's Avatar
Suspension Yoda
This thread is so old...
If you posted your intention, we could help you out.
Old Sep 3, 2006 | 07:26 PM
DcMaN's Avatar
grab a test light and ground it and touch each wire on the harness with the test light when you find the correct one the antenna should power up
Old Sep 3, 2006 | 07:31 PM
djfrestyl's Avatar
Suspension Yoda
Test lights don't give power?
Old Sep 4, 2006 | 05:20 AM
DcMaN's Avatar
no but it would complete the circuit..... Like when your testing wires for car alarms... When you use a test light to find the door lock wire if you touch it you hear the relays in the door click and and see the doors lock/unlock, same goes for headlights, horn, and other accessories like that i dont see how it would be any different for the power antenna..
Old Sep 4, 2006 | 07:32 AM
djfrestyl's Avatar
Suspension Yoda
That's news to me. When I use a test light it's got a red and green light. If you probe the wire and use the button/switch for whatever you're testing (eg, lock the doors) if the light goes to green, its ground, if it goes to red, it's power. If it's momentary like a door lock is, it will go to red then back to green.
Old Sep 4, 2006 | 01:41 PM
DcMaN's Avatar
hmm thats weird i have a snap on test light and it always powers up the device that im probing for.
Old Sep 4, 2006 | 01:42 PM
djfrestyl's Avatar
Suspension Yoda
We may be talking about the difference between a reg test light and a computer safe test light? I could be wrong. Good info to know that there is one that actually provides power.
Old Sep 4, 2006 | 01:56 PM
DcMaN's Avatar
the test light i use has an actual light in the middle that lights up when it receives power. Im sure any one like that would work fine.
The Frye
Sep 2, 2021 11:03 AM
Violator
Sep 9, 2015 10:14 AM
crazyespn
Sep 3, 2015 01:30 PM
