dynamat???
Old Mar 11, 2005 | 09:56 PM
maxim82's Avatar
dynamat???
what do you guys think of putting dynamat in all of the interior, doors and floor
Old Mar 11, 2005 | 10:00 PM
kpr10is's Avatar
What kind of system do you have that this is necessary? Because in most cases, all that isnt necessary, the doors and trunk would help. If you want to go all out and have the money/time, more power to you, because IMO you cant have too much dynomat, but the whole interior might not really be necessary.
-kevin
Pearl96Max's Avatar
I tend to get a bit irritable
Dynamat the name brand? No
Dampning in general...Love it! Did everywhere in my car and Im going in for more....
Old Mar 11, 2005 | 10:05 PM
Maxima-Ness's Avatar
look at stuff like SecondSkinAudio.com or Edead. On SeconSkin's website, if you sign up for thier forum and post more than 100 threads or replies, youll get 10 percent off your order! The more you post the more you save! And the Spectrum V3 stuff is said to be the shiznit!!! And BTW, Im preparing to do the same thing, and Im confident in SeconSkinAudio and its a lot cheaper than the Dynacrap.
Old Mar 11, 2005 | 10:21 PM
maxim82's Avatar
i just want this to make the inside as quiet as possible, anyways i was thinking of something that doesnt even belong in cars its called iceguard its something they use in roofs of houses, its adhesive on one side and it also has the same thickness and density as dynamat, by the way this stuff is about $70 for a 150sq ft roll
Old Mar 11, 2005 | 10:24 PM
The spectrum V3 is a pretty cool product. a typical car of our size takes about 3-5 gallons of. yes gallons, its kind a "gel" or tacky. You just paint it on and its waterproof and really kills road noise. It also is good to use in the wheel wells where you get a lot of the noise coming from the rear wheels and rear panels.
Old Mar 11, 2005 | 10:35 PM
maxim82's Avatar
when it dries up does it still remain like a gel or does it dry up, where can i find this
Old Mar 11, 2005 | 10:57 PM
kpr10is's Avatar
Not a big fan of paint on deadener myself. Rich (slickrick) has edead all over his trunk...parts of it are peeling/falling now with his Avalanche in there To each their own, but ill stick with rolling mine on.
Don, I thought you were selling your car?
-kevin
Old Mar 12, 2005 | 01:18 AM
slickrick's Avatar
yeah go with the mat based stuff if you dont mind installing it. although i am curious about the SS spectrum v3. liquid.
Old Mar 12, 2005 | 06:53 AM
Pearl96Max's Avatar
-kevin
I am, but Im never done putting things into it...
Old Mar 12, 2005 | 07:01 AM
Tony Fernandes's Avatar
Dynamat by itself (or any generic version of it) won't do anything to quiet the interior of your car. You'll need a combination of a damping material (like Dynamat) and a barrier that actually blocks noise. There are some companies that make a flexible lead sheet sandwiched between two damping layers but it would be VERY expensive and if I'm not mistaken will add a ton of weight to the car. If you want to reduce interior road noise, buy quieter tires, make sure all the window and door seals are in good condition, and use a noise blocker on your firewall that's specifically made for firewalls. I know, not exactly what you wanted to hear, but it's the truth.
Tony
Old Mar 12, 2005 | 01:39 PM
A32Matt's Avatar
how much weight is added using second skin, say all around your car (doors, trunk, wheel wells, floor, etc.)? i would be interested to know because if it does not add much weight then it would be worth it to do the entire car, at least in my situation with the roadnoise and whatnot.
Old Mar 13, 2005 | 09:08 PM
Check out SecondSkinAudio.com, they have a forum there and contact info.
Matt93SE
May 24, 2019 02:58 PM
killaSin11
Mar 28, 2002 10:49 AM
MichaelAE
Jan 2, 2002 01:15 PM
gma6188
Oct 11, 2001 11:52 PM
TurDz
Sep 8, 2001 07:47 AM
