Painting a Sirius Antenna??
Old Mar 16, 2005 | 04:37 AM
joeeey's Avatar
Could it be painted without causing any problems? I rather not have that big black bump on my roof when my Max is white. I wanted to paint it but I'm not sure if it's gonna cause a problem with it working. Thanks Joe
Old Mar 16, 2005 | 08:15 AM
HarleyJoel's Avatar
You can paint it without problems as long as it does not have metallic flake in the paint. I've heard some that have used the metallic flake paint have had problems but some have not had problems.
Old Mar 18, 2005 | 04:25 PM
HarleyJoel's Avatar
I just thought of a way to test if the metallic paint will affect the reception; wrap the antenna with Saran Wrap or the like, then paint the antenna. Try it out and see if it affects your signal. If it does - take the wrap off. I've heard a number of success stories when painting the antenna though.
Old Mar 18, 2005 | 08:03 PM
GodsmackMAX's Avatar
Just a suggestion... Try using this semi-new paint called Krylon Fusion. (no i don't work for them LOL) It works really well for bonding to plastics. I assume the Sirius antenna is plastic.
I painted my modified ex-Dell computer case with this paint and it looks like the damn thing came colored like this from the factory.
Good luck!
drew
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
chisam14
Nov 6, 2018 08:56 PM
DBear
Sep 14, 2015 08:33 PM
