oh crap I think I broke it
Ok so I was hooking up my JL 500/1 to my sub and i didn't unhook my battery cause i was lazy. I put in the RCA and the mono output wires first then I put in the power wire and then I was putting in the ground and i got sparks. So I thought that they had touched each other so I took them out and tried again got sparks again. So then I tried to put in the ground and then the positive I got some sparks but I decided ok I'll just finish this and hooked it up and turned it on. When I did that the Power light turned on but I got no sound from my subs and then some smoke and a burning smell. Does anyone know if I maybe just blew a fuse or did I just kill my amp?
gen3, dont be lazy next time and do it the right way, if your not gonna disconnect the battery at least take out your fuse! i mean now doesn't it make more sense to not be lazy and do it the right way instead of risking it , breakin something, and puttin yourself in a hole bcuz now you probably gotta spend more $$$ than you had planned.
no when i hook shyt up i put everything in and then the fuse is the last thing i put in....yah if ur gains are all the way down on ur amp you wont hear ur subs....so hook it up again and turn ur gain up and see wat happens ??? and wat were u touching together to get sparks?
Originally Posted by Tek-Niq
you should always hook the ground first before anything...
Ground first shouldnt matter. Get a multimeter and test the RCAs at the amp on alternating current, turn the volume up and see if the reading on the DMM goes up correspondingly. If so your input is fine. Put your multimeter on alternating current on the (+) and (-) outputs of the amp and do the same thing. What does it read/does it go up and down with volume? If not, I hope you have warranty.
-kevin
-kevin
220k+ A32
Sep 23, 2015 03:38 PM
