Installed PAC-ROEM-NIS2? Step in.,..
Old Mar 16, 2005 | 03:07 PM
irish44j's Avatar
retired moderator
I'm doing the wiring from my new deck through the PAC-ROEM-NIS2 and have one question:
The deck has the usual + and - wires for each speaker, but the adaptor (with chart) has a - wire and a + high level and + low level for each speaker. I suppose this is a split to the tweeter and door speakers? My question is, do I just crimp the +high and +low together and connect them to the Alpine + wire for each speaker?
Seems like an obvious answer, but I just want to make sure....
thanks!
Old Mar 16, 2005 | 03:15 PM
irish44j's Avatar
retired moderator
one other thing....since the 5th gen doesn't have a power antenna, do I just leave both ends of the power antenna wire unattached, or should I attach them?
Old Mar 16, 2005 | 04:37 PM
Matt93SE's Avatar
STFU n00b!
the high level and low level are for speaker level and amp level signals.. if you connect them, you're going to damage circuitry..
If you harness has a power antenna wire on it going to the car, then you'll need to hook it up. I'm not sure on the 5th gens, but on the 3rd gens, that same wire told the Bose to power up... If you didn't connect it, tbe BLose wouldn't work...
Old Mar 16, 2005 | 04:45 PM
irish44j's Avatar
retired moderator
Thanks Matt....so I would assume I leave 4 of the wires unconnected then? Would I leave the +high or the +low loose?
Old Mar 16, 2005 | 04:55 PM
nismo0604's Avatar
pm tek-nik, he installed mine with that adaptor
Old Mar 16, 2005 | 04:57 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
I didn't leave no wires loose on your install nismo.....
Old Mar 16, 2005 | 04:59 PM
99 SE-L
irish i just installed my headunit and i did not have a antenna adapter and it would not work but 5 th gens are made dumb and dont have stock ground ground it will work wihtout a adapter maybe this will help.
Old Mar 16, 2005 | 05:04 PM
Tek-Niq's Avatar
same with nismo's install. the antenna didn't fit with the oem harness, so I hooked it up to the pac anyway just incase he desides to get the proper harness. but as for the spk wires I hooked them all up to the pac. I left no wire hanging... if you got the same one as nismo did you should have all the wires connected..
Old Mar 16, 2005 | 05:05 PM
irish44j's Avatar
retired moderator
Here's what the Alpine has coming OUT in terms of speaker wires:
front right speaker gray + gray/blk -
front left speaker white + wht/blk -
rear right speaker purple + pur/blk -
rear left speaker green + grn/blk -
now the adaptor speaker wires:
front left
+ low level wht/red
+ high level wht
- wht/blk
front right
+ low gry/red
+ high gry
- gry/blk
rear left
+ low green/red
+ high green
- grn/blk
rear right
+ low purple/red
+ high purple
- purple/blk
now all the other wires match up identically, so should I just leave all the "low" wires unattached to anything, since there is no low/red stripe wires coming from the deck?
Old Mar 16, 2005 | 05:07 PM
irish44j's Avatar
retired moderator
I got the PAC-ROEM-NIS2.....but as you can see above, there are high and low speaker positives...which to use is the question.
As to the antenna, I have an antenna adaptor...I was asking about the "power antenna" wire (blue wire) from the harness and deck....
Old Mar 16, 2005 | 05:11 PM
Tek-Niq's Avatar
ok hook up the high side then accordingly to your HU. you don't want low sound coming from your cab spk's...
irish44j's Avatar
retired moderator
what I mean is the PAC wiring diagram denotes a LOW LEVEL (+), a HIGH LEVEL (+) and a (-) for EACH speaker.....but of course the Alpine wiring only has a regular (+) and (-) wire...2 wires, not 3.
Old Mar 16, 2005 | 05:12 PM
irish44j's Avatar
retired moderator
ok that's what I figured, just wanted to be sure! thanks.
Old Mar 16, 2005 | 05:21 PM
Tek-Niq's Avatar
ok cool, you should be all set. these pac adapters are pretty simple to work with.
are you sure you adapter is the PAC-ROEM-NIS2, this name isn't valid, you must have the PAC-AOEM-NIS2 is this right?
Old Mar 16, 2005 | 05:24 PM
irish44j's Avatar
retired moderator
The ROEM-NIS2 is for using a/m deck with stock/bose speakers
the AOEM-NIS2 is for using Bose deck with aftermarket speakers....
Old Mar 16, 2005 | 05:27 PM
Tek-Niq's Avatar
ah, now you helped me out, you see how things work...
Old Mar 16, 2005 | 06:08 PM
dadiesel's Avatar
Where can I buy one of these? I will be installing a Jensen in-dash dvd next week to my stock speakers .
Old Mar 16, 2005 | 06:19 PM
irish44j's Avatar
retired moderator
most high-end audio stores sell them....Tweeter, Myer-Emco, etc...or online at crutchfiled and other places
Old Mar 17, 2005 | 05:37 AM
TAPOUT's Avatar
You will lose
You are only supposed to use the high level +. The low level + would be for using the RCA preouts, and cutting the cable to hook it up. You do have a powered antenna...hook up the blue wire. It is in the rear window, but it is amplified.
Old Mar 17, 2005 | 12:06 PM
irish44j's Avatar
retired moderator
outstanding....that's the way I did it
thanks again for the good deal on the deck and the help Jason, see you around!
Old Aug 13, 2008 | 04:37 PM
Dust N Bones's Avatar
Sorry to bump an old thread but this question is relevant. Does the PAC ROEM-NIS2 require any manual adjustments? Or is it basically just plug and play after wiring it to the after market H/U?
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
ag90fox
Sep 9, 2015 12:22 PM
Johnny9595
Sep 3, 2015 05:18 AM
