Problem with Sony xploid Amp
Old Mar 22, 2005 | 06:24 PM
Makavelidadon's Avatar
I have a 1 channel 1600wsony xplode amp ..........i havent used it for a while, but when i finally hooked it up to a sony xplode 12" amp the red light on the amp keeps showing, and the amp wouldn;t work........what does this usually mean? HELP HELP HELP
Old Mar 22, 2005 | 06:47 PM
03SE2HEAR's Avatar
Is that the power LED or a protection LED?
Old Mar 22, 2005 | 07:57 PM
BRINKLEY's Avatar
I think I'd check the fuses if I were you. I had it on my amp once, and it was a blown fuse.
Old Mar 23, 2005 | 01:15 PM
I checked the fuses and all of them were intact because the amp has 3 40a fuses......and non of them were blown......The protection LED Shows.
Old Mar 23, 2005 | 01:20 PM
mdmartin92's Avatar
Disconnect all of the speaker wires and see if the problem goes away. If it does you hooked up your speakers wrong.
Old Mar 23, 2005 | 01:47 PM
so i should disconect all the speaker wires and just hoook up only th amp?
Old Mar 24, 2005 | 04:20 AM
mdmartin92's Avatar
Yup, Disconnect the speaker outputs and see if the protection LED goes out. I have a sony explode amp also and had a short in my speaker wires and the protection LED came on. Corrected the short and the fault LED went away.
Old Mar 24, 2005 | 04:25 AM
2 Da Max's Avatar
lol my xplod amp got burnt up, neways check the wiring of the sub, maybe the sub is wired down to 1ohm and the amp isnt 1ohm stable.
Old Mar 29, 2005 | 08:03 AM
When i start the car, the regular green light comes on, but after like 5ecs it goes to the LED Protection light....................... when the LED protection light comes on, does it mean the amp is blown?
Old Mar 29, 2005 | 09:18 AM
tothemax319's Avatar
Its oveloaded... happened to me before with my 760watt 2-channel Xplod.. Just couldn't pump any power, and would give up after a few minutes.
Old Mar 29, 2005 | 11:44 AM
so what did u do? or what can i do to solve this problem????
Old Mar 29, 2005 | 12:43 PM
mdmartin92's Avatar
Have you tried turning the amp on with the speakers unloaded yet? By this I mean with all speaker outputs disconnected.
Old Mar 29, 2005 | 02:18 PM
No, let me go try it now.............bump
Old Mar 29, 2005 | 10:07 PM
Try using a better ground location. Also check to make sure nothing is crossed or touching between the ground and power terminals.
Old Mar 30, 2005 | 06:09 AM
djfrestyl's Avatar
Suspension Yoda
your first problem is that its a sony amp
check all your connections and fuses - maybe theres an internal breaker?
ivorton23
Sep 28, 2015 09:08 PM
popdedop
Sep 11, 2015 11:17 AM
