Left front speaker goes in and out
Old Apr 7, 2005 | 07:11 AM
tmc's Avatar
tmc
02' GLE with Bose. The left front works fine and then stops sometimes...occurs when I make a turn or hit a bump. Any suggestions?
Thanks.
Old Apr 7, 2005 | 07:25 AM
MacAlert's Avatar
Take it to the dealer and have them replace the HU, there's a TSB for it. That will eventually die on you again. I say just get an aftermarket HU, you will have no problems.
Old Apr 7, 2005 | 07:30 AM
MannyNJ2k2max's Avatar
exactly-i went aftermarket the second it happened to me- in my car and my 2k1 Pathfinder it was the drivers side cutting in/out
Old Apr 7, 2005 | 08:48 AM
tmc's Avatar
tmc
Thanks for your help. I called the dealer he said it's $1400 to replace the HU. Any other suggestions??
Old Apr 7, 2005 | 10:31 AM
MacAlert's Avatar
Uhh, they should replace it for free. There is a TSB out, print it out and take it to them
Saved you the trouble of having to find it:
http://maxima.theowensfamily.com/tsb/NTB03-017.pdf
Old Apr 7, 2005 | 11:55 AM
tmc's Avatar
tmc
I understand the TSB but I'm no longer under warrantee, hence I have to have it replaced.
Old Apr 7, 2005 | 12:25 PM
MacAlert's Avatar
If that's the case, don't waste your money on the stock HU. If you have the money, go aftermarket.
Old Apr 7, 2005 | 12:28 PM
With the $$ it would cost you to replace the OEM HU, you can build a high fidelity sound system-speakers, HU and amp
Old Apr 18, 2005 | 09:34 PM
00SEMAX19's Avatar
Had same prob. decided to try and fix it myself. Took HU apart and looked around abit, made sure all inturnal plugs were tite check for cracks in the boards, and put it back together. Fixed problem for 2 weeks now, (use to f--k up everyday) guess I got lucky because I didn't realy fix anything, just screwed up the tape player that I never use.
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
dvcamp
Sep 18, 2015 10:17 AM
jfl330
Sep 4, 2015 01:44 PM
A32goldylocks
Sep 2, 2015 06:39 AM
