i finally decided on my setup guys
I decided I'm getting an Atlas 15 subwoofer and a Profile AP1000M amplifier. I will build my own box because I got a box diagram from sunten1, unless you guys have a better idea for a box. It is a ported box, you think that will go good with the Atlas 15? I can't wait to get this stuff.
Originally Posted by AscendantMax
it's better to be slightly over powering then underpowering a sub. but again...power handling is box dependant.
box dependant..can you explain that a little more...the bigger the box the bigger the chance the sub will blow or opposite?
Originally Posted by slickrick
the larger the box...the easier it is to break the sub mechanically. "overexcursion" can occur easier because the sub has more air to work with.
thanks a lot bro..thats the perfect answer to my question and now i know not to oversize a box
well don't take it that far. for some sick low end with a loss in spl a big sealed box is very nice.
i had 2 10" subs in a very large sealed box and i swear they got a little lower than my 15 does. but my 15 is ALOT louder than the 2 10's.
I just baught a diamond audio M6 (earlyer known as mack daddy), a 1200 watt performance teqnique amp, 4 gage amp kit, seald mdf box, and install. and all for how much? 420!!! My stereo guys are great for giving awsome deals. and this single 12 beats harder, deaper, and fuller than my buddy's two 12' Kicker CVR's. And SQ is equal if not better than my buddys W6. It is the perfect sub to buy IMO.
damn that does look soo nice..i just found out that the Ascendant Audio store is 30 minutes from my house..i'm going to go over there and check out the avalanche and the atlas this week
man, i wished a kick **** company was close to me
see if you can get more info about the avalanche 12"
yeah i'll try to get information on all those subs, might even come home with an atlas or an avalanche
haha yea guys the only downside is that i hear that for the Atlas you need a reaaal big box..i wonder what will happen if i build a SEMI-big box..like slickrick's
i just reaaaly dont want to go any bigger and take up the whole trunk
hey i forgot to ask..does the amp wiring kit come with everything i need? as in the battery hook up things and all the necessary wiring? i know ill have to buy the terminal cup for the box but what else would do i need that doesn't come in the amp wiring kit? aNnnnnd should i buy some stuffing for the box? or is that not necessary?
looks pretty solid..you didn't jigsaw the hole yet? how much did the MDF run ya?
don't overkill on the screws. the glue will be the component holding the box together. the screws are there to hold the pieces in place for the glue to dry.
Aaron - going to work on this box right now...
quick random tip for making the cutout...if you happen to have a drum pad use that and trace a circle.
3/4" MDF = HEAVY + SUB AND AMP MOUNTED
Do you think I could get away with mounting the amp on the box?
Cool, I don't believe I have a drum pad so I'll use a compass. I'll cut it out as soon as I get the sub and find out the diameter hole I need.
