Problem: Subs slide around in the back...
Old Apr 17, 2005 | 12:37 PM
WillMax95's Avatar
I know what you're already thinking, "BOLT THEM TO THE GROUND IDIOT!!"
...But I can't, I need to be able to get under the subs and there really isn't a good spot to bolt them down. So...
I have a 95 Max with 2 12" subs in the back, they are in a single box and they slide around. The carpet slides with them too, so when I open my trunk, the carpet is all bunched up to one side along with the subs. Has anyone found a remedy to this that would prevent the carpet and the subs from sliding around and still give access to under the carpeting. I was thinking of Velcroing the carpet to the floor that way the carpet wouldn't slide...anyone tried this?
Old Apr 17, 2005 | 01:15 PM
Scope's Avatar
Im izz sexay
You can either velcro or staple the rug to the ground. Then just put velcro strips on the box and carpet.
Old Apr 17, 2005 | 01:43 PM
AscendantMax's Avatar
velcro didn't work for me. it just bunched up the carpet even worse. my cheap solution...bungee cords. i got 2 cords (since 1 isn't long enough) and have holding my box in towards the rear seat. it's hooked to the metal frame thingy that goes across the rear seat. works rather well, even though my box+sub is at least 100 pounds.
Old Apr 17, 2005 | 03:16 PM
slickrick's Avatar
velcro does not work from my experience. if you want put a 1/2" piece of wood under and use lbrackets...make a hinge if you want to keep your spare tire easily accesible also.
Old Apr 17, 2005 | 06:03 PM
1996blackmax's Avatar
I used some of those cords that have hooks on both ends, and you can tighten up by pulling it through a hinge type thing, this was on my 92 Maxima. There the ones that you can release the tension by pushing on a lever. They worked pretty well. I apologize for the lame description, but at the momonet I cannot remember what they are called.
Old Apr 17, 2005 | 07:11 PM
ruffrida24444
hey man ur local!! i have the same problem but was thinking maybe cutting wood liek this > and carpeting it and putting against my box so it cant really go anywhere. my box fits in the back perfect but idk wut u would do about it moving side to side
Old Apr 17, 2005 | 07:20 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
I also use bungee cords....
Old Apr 18, 2005 | 05:14 AM
WillMax95's Avatar
anyone got pictures of the bungie cords, i wanna see how you hooked it up
hey ruff, ill look for ya around town, i go up towards hillsborough sometimes
Old Apr 18, 2005 | 04:34 PM
Old Apr 18, 2005 | 05:33 PM
thephatOne's Avatar
seems many people are opting for the bungee cord option. as long as it works its all good
Old Apr 18, 2005 | 06:26 PM
slickrick's Avatar
damn gordon that box is sexy...much better looking than mine.
Old Apr 18, 2005 | 06:28 PM
roll4life's Avatar
Originally Posted by AscendantMax
do you have plans on how to make a box like that? or tips or anything..it looks great
Old Apr 18, 2005 | 06:33 PM
thanks rich...just excuse the jumper cables and my cue case
your sub > my brahma
Old Apr 18, 2005 | 07:21 PM
sachmo12345
Bungie Cords
Old Apr 19, 2005 | 04:39 AM
WillMax95's Avatar
oooo, i see how its done, i think im gonna have to do this. what did you hook the bunjie cords to in the back...also, do you have ne problems with the box falling over?
Old Apr 19, 2005 | 06:37 AM
nope, no issues of the box falling over. it's hooked to this metal bar thingy that spans the gap of the rear seat. if you're going to use bungee cords, make sure they're the heavy duty ones so it's harder to stretch. it'll 'pull' harder on the box keeping it in place.
James92SE
142
Jan 2, 2024 09:23 AM
boomerbrian
Oct 31, 2018 10:25 AM
Redfox
Sep 28, 2015 10:41 AM
dcam0326
Sep 18, 2015 04:52 PM
DBear
Sep 14, 2015 08:33 PM
