Amp Problems
Old Apr 29, 2005 | 04:20 PM
lilonasis's Avatar
Amp Problems
When I turn the radio on the subs will be powered for about 30 seconds and they'll stop bumping. I looked at the amp and it said over current. Any ideas?
Old Apr 29, 2005 | 05:30 PM
AscendantMax's Avatar
sub wired too low of an impedance?
Old Apr 30, 2005 | 03:11 PM
lilonasis's Avatar
What does that mean?
Old Apr 30, 2005 | 05:53 PM
1996blackmax's Avatar
For example, if your amp is stable into a 4ohm bridged/mono load, and your wire it to a spleaker or speakers with a final load lower than 4ohms it will shut down.
Kind of a lame exp. but my head is hurting right now .
You may have to wire only one sub to it. Let us know what kind of amp it is, brand and model, and any of the specs. Also do this for the subs. It will allow us to help you out more.
Old Apr 30, 2005 | 05:54 PM
Golden Ice's Avatar
how are they wired at the amp, whats the impedance of each sub (2, 4, 8 ohms?) and what impedance is the amp stable to?
impedence (resistance) is measured in ohms, most subs are either 2 or 4 ohms, some are 8. the lower the impedence, the more power it will try to pull out of the amp, but if it tries to pull too much power out of the amp, the amp protests by overheating and cutting off.
Old Apr 30, 2005 | 06:22 PM
WickedMax3's Avatar
Mine use to do that tooo. Check all your fuses and wiring. My amp gets too hot sometimes and i have to let it cool down when i bump it tooo much.
Old Apr 30, 2005 | 07:42 PM
what those guys said. give us the specs on the amp and sub so we can further help ya.
Old May 4, 2005 | 04:51 PM
lilonasis's Avatar
Okay here are the specs for my subs and amp. Please let me know if you can tell me what's wrong with the subs. thanks.
2 Verge 10" 300-Watt Subwoofers
Peak power handling (watts) 300
RMS power handling (Watts) Info unavailable
Frequency response (Hz) 35Hz - 1500Hz
Impedance (Ohms) 4
Sensitivity (dB) 88
Design
Subwoofer size 10
SONY XM-2150GSX amplifier
150 watts RMS x 2 at 4 ohms
190 watts x 2 at 2 ohms
380 watts x 1 in bridged mode
Stereo or Bridged Mono Output
Tri-Way Capable
MOSFET Power Supply and Output Stages
50-300 Hz high-pass/low-pass filter, 12 dB/octave
Line-Level and Speaker-Level Inputs
Gold-Plated Connectors
Preamp Outputs
Variable Bass Boost (0-10 dB) centered at 40 Hz
Signal-to-Noise Ratio 100 dB
Old May 4, 2005 | 05:11 PM
How do you have your speakers hooked up to the amp. Are they each connected to one channel, or do you have them bridged. If you have them bridged how are they connected to the amp( + to + and - to -)? If you are running the system bridged at 2ohms then here lies your problem.
Old May 4, 2005 | 05:29 PM
lilonasis's Avatar
How can you tell if they're hooked up to one channel or not? mine is hooked up - to -and + to +. Not sure if it's bridged or not this is my first setup. Any help is appreciated.
Old May 4, 2005 | 10:39 PM
Your amp has 2 channels (stereo), each channel has one + and one - . The amp can also be run to give all of its power to one channel (bridged). This is usually done by using the Positive (+) of one channel and the Negative (-) of the other channel.
Now, are the speaker wires that go to your speakers connected together at the amplifier end, or do they go to their own channel?
Old May 5, 2005 | 03:30 PM
lilonasis's Avatar
On my amp the speaker wires go to they're own channel. If the system was bridged would that correct the problem? I know it's a sh**ty amp but it shouldn't be this complicated.
Old May 5, 2005 | 04:44 PM
e r y k's Avatar
how are the speakers wired? parallel or series?
Old May 5, 2005 | 05:01 PM
they're each going to their own channel....
i would get a MM and check the voltage at the amp to see if its getting enough power. 2nd, i'd check the gains. also make sure the amp have proper airspace around it so that the heat can dissipate.
Old May 5, 2005 | 05:08 PM
e r y k's Avatar
could there be a possibility that there is a short somewhere?
Old May 5, 2005 | 08:45 PM
Could be. Check your speaker wires to make sure that they are not contacting any metal.
Also check what AscendantMax said.
By the way your speakers are wired the amp should not be getting stressed. So there must be some abnormal issue making it do this. If all else checks out, it may be time to send in that amp for repair, or upgrade .
Old May 6, 2005 | 04:19 AM
lilonasis's Avatar
What type of amp/ sub combo would you reccommend ?
Old May 6, 2005 | 07:50 AM
Do you want to change out your whole setup, subs and amp? Have you been able to figure out what is wrong?
As far as what setup people will recommend depends on your budget. Let us know how much you are willing to spend and we can give you an idea of what is available.
ivorton23
Sep 28, 2015 09:08 PM
popdedop
Sep 11, 2015 11:17 AM
