Newbie question on the design of the amplifier power distribution blocks.
Old Apr 30, 2005 | 08:23 AM
snair2's Avatar
Well, I was looking into the distribution blocks on Crutchfield, and most of all of them have 4 gauge wire input, and multiple 8 gauge wire outputs. The thing I am concerned with is, that isn't it better to have like 4 gauge wire outputs going to the amplifier, or does it no matter when it comes out of a distribution block? All the distribution blocks I seen on crutchfield have 8 gauge wire outputs... Someone enlighten me . For example, what if I use two 1000 watt amplifiers, shouldn't I use 4 gauge wires for the amps from the block?
Old Apr 30, 2005 | 08:28 AM
kcidmil's Avatar
Yep... you would need 4 guage for the amps, 0 guage for the input. If you are using 1000 watt amps. I run 8 guage for my 500 watt. But it's the only amp in my truck.
Old Apr 30, 2005 | 08:29 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
might have to go with a diff maker... here are the JL ones
https://www.jlaudio.com/ECS/pdb.html
you might be looking for the first one there...
Old Apr 30, 2005 | 08:41 AM
jigga123's Avatar
http://www.canze.org.nz/bcae/caraudio.htm, try this site. If your new to car audio andwant to learn about it, this site has everything you'll need to know. Its very informative and very helpful.
Old Apr 30, 2005 | 08:54 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I would actually recommend the stuff found @ knukonceptz.com
Old Apr 30, 2005 | 08:57 AM
danhaman's Avatar
It really depends on the length of run of wire [most cars have the batteries in front, so I'll assume 12' to the distro block], the amount of acceptable voltage drop [most recommend no more the .5V], how many watts [I'll use the 2k you said, but if you are going to have an additional 4 ch amp for the front stage, you should add that in, also <assumes RMS wattage given>], and how efficient the amps are. Here you'll probably have to generalize, if using class A/B for the front, and D for the back, etc. . .[I'll assume 65% efficiency, since you're likely talking about class D amps]. Given that scenario, I would run 2awg to the distro, then 4 awg to the amps. However, it would not be a bad idea to run 0awg to the distro, in case you ever want to increase power in the future. Also, when running in excess of 2kwatts, your electrical system may have some trouble keeping up [I'm not all that familiar w/ the max/i35 electrical system, yet]. So, once it's all hooked up, keep an eye out for a distressed electrical system [battery keeps dying when you're only listening to your stereo w/ the car on. . .]
Hope this helps.
dh
Old Apr 30, 2005 | 09:18 AM
AscendantMax's Avatar
distance is a factor when it comes to wire sizes.
Old Apr 30, 2005 | 09:50 AM
kcidmil's Avatar
Hey we found a guy we can let loose on the audio forum to save us a headache... now if we could just get slickrick to keep 2DaMax inline
Very nicely done danhaman
Old Apr 30, 2005 | 10:28 AM
slickrick's Avatar
i just got on the ball again today...
Old Apr 30, 2005 | 10:30 AM
it's a team effort to keep 2 da max in line
Old Apr 30, 2005 | 10:37 AM
kcidmil's Avatar
Tell me about it... anyone know exactly what his little 99 conversion entales????? I have a feeling it is something completely insane... and hazardous to the rest of us
Old Apr 30, 2005 | 11:04 AM
slickrick's Avatar
i told him to save up another 1k and just buy a 2k-2k2 maxima...
The Frye
Sep 2, 2021 11:03 AM
Maximan190
Dec 16, 2015 06:01 AM
AT978
Sep 6, 2015 10:31 PM
sdotcarter
Sep 2, 2015 09:53 PM
