5th Gen Din Kit w/ Pocket??
Old May 4, 2005 | 10:16 AM
Ryals's Avatar
SHIFT_this
Has anyone with a 5th Gen Maxima installed a aftermarket DVD flip out screen with the pocket on top instead of the bottom. I was looking for a few examples to see what it looks like on top and bottm so I can decide how I want mine installed? Pix would be appreciated!!
Old May 4, 2005 | 10:48 AM
slickrick's Avatar
like this?
Old May 4, 2005 | 10:55 AM
Ryals's Avatar
SHIFT_this
Exactly!! What Din Kit is that? Who makes it?
Old May 4, 2005 | 10:59 AM
slickrick's Avatar
scosche kit. however prepare yourself for some time to make the kit fit perfectly because it does not like up perfectly. you can go with the gxe dash kit but thats about $90 as opposed to about $15. however, its a perfect fit and color match.
Old May 4, 2005 | 12:05 PM
TheBigDu's Avatar
Pocket can go on top or on bottom. I only paid $50 because I got it used (but in very good shape) from an org member who sold his Max.
-Brian
EDIT: That pic was obviously taken during my amp install, which is why the car looks like sh*t.
Old May 4, 2005 | 12:07 PM
slickrick's Avatar
i love that gxe kit...
Old May 4, 2005 | 12:11 PM
TheBigDu's Avatar
It's pretty nice except for the gap it leaves around the stereo, since the HU trim piece won't fit. I know Irish used a trim piece from another mounting kit; guess I'll have to find one somewhere. I don't like the gap on the bottom through which you can see the wiring.
Old May 4, 2005 | 02:36 PM
Ryals's Avatar
SHIFT_this
Yeah I like that kit but where do you get that pocket? Does it come with the Kit? The gap doesn't look too bad from the pic. Would everyone perfer the GXE piece over the Scosche kit? I had difficulty with the scosche kit when I first switch to after market, so I used the other kit instead. Another question which would be more difficult for a theif to get out? Just in case!!
Old May 4, 2005 | 02:51 PM
TheBigDu's Avatar
Yeah, I'm sure everybody would prefer the GXE kit since it looks so much nicer, but the question is, do you want to spend $100 for one?
The pocket is technically a separate piece, but I think you can get both the trim (vents + ring around 2-din opening) and the pocket for ~$100. Check http://www.courtesyparts.com.
I used to have the Metra kit (different than Sosche), but it was way too ugly IMHO.
As anybody else will tell you, which dash kit you have isn't going to have an impact on whether a theif gets your HU or not. But, since you asked, with the GXE kit, the HU bolts directly into the metal brackets that hold it and the HVAC controls. With the Metra kit, the HU simply slides into the front, and can be removed without actually removing the trim. (This may vary depending on HU brand.) I'm not sure about how the Sosche kit works.
-Brian
Old May 4, 2005 | 03:27 PM
Ryals's Avatar
SHIFT_this
Good point on that theft thing!! I know abot the GXE kit, but I was confussed as to if the pocket came with it or not. Can anyone confirm rather or not you get the pocket when you order the kit from nissan?
Old May 4, 2005 | 07:27 PM
merovi's Avatar
i actually prefere the metra kit. i looks alot better then i could ever get my GXE to look. the cd player would either stick out too far or not stick out far enough. the metra kit also does bolt under the vents so it is not as easy to steal as u mentioned.
Old May 4, 2005 | 08:03 PM
kpr10is's Avatar
yes the metra kit bolts in but the radio slides right out of its cage with that kit.
you can always redrill holes in the OEM Brackets with any other kit, such as slickrick posted above
Old May 5, 2005 | 08:49 AM
Ryals's Avatar
SHIFT_this
Well I went ahead and ordered the GXE kit, wit the pocket from the 4th Gen max from Dave B because it has the door on it to cover the pocket. If i don't like it I guess I'll just change it.
MAXSE5SPD
Sep 17, 2022 04:00 AM
pktaske
Sep 4, 2015 08:40 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
