air horn and alarm setup
Old May 4, 2005 | 12:41 PM
silvermaxSI's Avatar
i have a viper 791xv alarm setup and i also have air horns hooked up now my question is, How do i hook up the alarm siren to the air horns so that when the alarm goes off botht the siren and air horns go off
Old May 4, 2005 | 05:35 PM
kpr10is's Avatar
How are the air horns wired and what triggers them? Youll most likely just need a relay which is <$10 anywhere.
Old May 4, 2005 | 07:28 PM
my air horn are tapped into my regular horn so all 3 go at the same time (2 air and Nissan Horn) do i have to tap in the wire thats in the column
Old May 4, 2005 | 08:00 PM
kpr10is's Avatar
Assuming our horm wire is negative trigger since most maximas are, and that your air horns are negative trigger also, than yes youd connect the output from the alarm brain to the air horn wire at the steering column, or connect it to the horn wire itself if you want all 3 horns to go off.
Old May 4, 2005 | 09:30 PM
mclarengts1's Avatar
so does your air horn sound like the big truck horns?
Old May 5, 2005 | 12:47 PM
lol no not those kind of air horns more like ferrari air horns that kinda things and can anyone tell me where the horn wire is not the one located in the steering column
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
