alarm installation question
Old May 14, 2005 | 05:44 PM
nismo2ner's Avatar
down with Bing
Ugg 3rd weekend of doing this and i finally have everything wired in right and everyting works BUT...... it wont unlock it will lock but wont unlock....
so i read up and in small print it said it needed a double pulse for the unlock to work.
What the heck does that mean??? :S
Can anyone give me a pointer... is it another wire or what do i need to do?
Thanks alot o Its a 95 SE 5 speed
Old May 14, 2005 | 09:45 PM
nitromax's Avatar
our cars have what is known as driver door priority unlock. press unlock button once on remote to unlock the driver's & a second time within 3 seconds to unluck the others. that said, means you'll probably need to add a relay and 2 (1-2 amp diodes) to the circuit in the driver's door to create the double pulse signal for the add-on alarm. since I don't know what alarm you're using, I suggest contacting the manufactorer for necessary diagrams and parts. You can get the parts from Radio Shack also Omega sells parts and has diagrams- --770)942-9876 or techline 770)942-5400. hope this helps. Oh yeah, I went thru this same thing 3 yrs. ago ,when i did my alarm.
this is an add-on alarm you're working with, right?
Old May 14, 2005 | 09:55 PM
Ruthless's Avatar
What a double pulse is, 2 jolts of electricity.
for normal computer circuits its either +/- 5 volts or +/- 3 volts or +/- 12 volts
My guess the car is 12v, since the battery and everything else is 12v. MIGHT BE WRONG!!!! CAUTION!!!!
For the record, if i use the door lock on the drivers door, all doors unlock/lock in 1 push. MY Nissan key fob opens drivers door with one push and all the others with 2.
my $0.02
PH98I30
Jan 9, 2025 08:08 AM
kmitchel
Oct 28, 2015 09:46 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
mikekay
Aug 10, 2015 12:52 PM
