Reception Problemo
Old Jun 3, 2005 | 06:21 AM
2K3MAX2NV's Avatar
"tse-tse fly"
Reception Problemo
Ive had a new reciever for some time now and my AM/FM reception SUX!! When I asked the guy who installed my new HU he says "yea the antenna's on these cars suck" meanwhile my stock HU was fine so what can I do here?
Old Jun 3, 2005 | 08:08 AM
MannyNJ2k2max's Avatar
what hu? do you have tint on the rear window?
Old Jun 3, 2005 | 09:18 AM
Komax's Avatar
tints have nothing to do with the reception
there's a thread that discusses this problem (which I also have) in the 5th gen forum
Old Jun 6, 2005 | 01:26 PM
2K3MAX2NV's Avatar
"tse-tse fly"
yea the rear window is tinted but I dont think that is the problem, like don says I think the wiring wasnt done correctly but I dont have a clue about that stuff
Old Jun 9, 2005 | 03:09 PM
Komax's Avatar
i just fixed this problem. i tied the yellow wire (12volt), blue wires (power antenna) and ground together and now everything works great! i get reception just like with my stock head unit!
btw, i have a Pioneer deh-4700mp.
Old Jun 9, 2005 | 08:43 PM
toodark's Avatar
tint DOES affect your reception if your window is tinted with HP TINT
Old Jun 9, 2005 | 08:58 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Actually unless you tint the OUTside of your window, thats incorrect.
Old Jun 9, 2005 | 08:59 PM
Pearl96Max's Avatar
Do you own a fire extinguisher?
Old Jun 14, 2005 | 11:22 AM
Komax's Avatar
do u own a life?
the wiring is the direction of Scoche.
Old Jun 14, 2005 | 11:45 AM
Pearl96Max's Avatar
do u own a life?
Yea umm I do. In my life I include common sense.
PLEASE show me ANY directions that tell you to put POSITIVE +12 together with NEGATIVE -12
I beg of you to PLEASE SHOW ME THIS
Old Jun 14, 2005 | 11:53 AM
slickrick's Avatar
do u own a life?
lol, "the Don" is getting flamed hardcore in his own forum...you need to hire a hitman...or just ban people.
Old Jun 14, 2005 | 12:05 PM
ny96max's Avatar
Don, if this kid knew anything he would know that in the Metra harness for 95+ Nissans the Black "ground" wire doesnt exist on the stock side of the harness, hense wont do a thing if its powered. Ill also bet he doesn't know that the stock antenna grounds the radio.
Ant
Old Jun 14, 2005 | 12:13 PM
Pearl96Max's Avatar
Ant
Very true Ant, but in light of the situation, he passes this info along to someone else (maybe different car) who actually connects power and ground together .......
Old Jun 14, 2005 | 12:14 PM
Pearl96Max's Avatar
Flame = what happens when you put power and ground together...
Old Jun 14, 2005 | 04:49 PM
TheBigDu's Avatar
Back to the question at hand...
I had this same reception problem when switching to my Alpine HU. Through talking with a local installer and with Don, I learned that the problem lies in the Nissan antenna. It's actually a good antenna, but ONLY for the stock HU. The stock HU is tuned to work properly with the window antenna. Aftermarket HUs are not designed specifically for this kind of antenna, so they get nearly NO reception. The little 2-1 pin adapter doesn't do crap, basically.
The only solution to this problem is to install an antenna somewhere on your car. I've gotten to the point where I really want the ability to listen to the radio, even though I won't do it much. I've decided to look into getting an antenna like the current VWs or corollas. (The short black thing that sticks up at the rear of the roof.) Those don't look too bad, IMHO.
-Brian
Old Jun 14, 2005 | 06:02 PM
JoE'sMaX01's Avatar
um... i have an aftermarket pioneer radio, at first i had the same problem wit the reception however all you need to do is connect all the blue wires together because one of them is your amp wire for speakers one is the antenna wire, now u connect both those wires with your blue wire coming from the headunit you will have great reception. I believe this will help you in the problem here. Don't connect any constant 12v (yellow wire) to your blue (antenna/remote) this isn't nessecary to amplify your antenna to have good reception.
Old Jun 14, 2005 | 09:19 PM
Komax's Avatar
Correction on my part. As per the Schosche instructions, it's all the blue wires with the 12 volt. I DID NOT twist the ground...that was a typo above. I grounded the proper wires via the antenna adapter and just one more the chassis.
And for a moderator or whatever doofus you are, "Don", you should know better that EVEN if wrong wires were connected, that's why there is something called "fuses". I dare you to ban me. Arrogance is no charm my friend.
Old Jun 14, 2005 | 09:46 PM
Pearl96Max's Avatar
So let me get this straight, you admitted to a typo or whatever your problem was, either way you were wrong. You then tell me to get a life. And I am the bad person here?
Your comments of arrogance suit you quite well, with your name calling and attempts at threats. Please dont "dare" me to ban you, ask around I am one of the most leanient Mods here and I dont ban much, but I also wont hesitate for just cause.
Old Jun 14, 2005 | 09:52 PM
slickrick's Avatar
yep he is. although doofus is a funny word...yet it only should apply to YOU!
Old Jun 15, 2005 | 04:07 AM
TheBigDu's Avatar
Old Jun 15, 2005 | 05:43 AM
Act your age..... you were wrong, take it like a man.
Old Jun 15, 2005 | 06:33 AM
Komax's Avatar
it's all good, i forgive you "Don"
Old Jun 15, 2005 | 08:50 AM
Dohcser's Avatar
Komax for a person of your age you don't act it. How could you make a TYPO when you clearly state to tie it to "ground". What did you fat finger the whole word "ground"? Anyway like Manny said be a man admit your ignorance and move on.
Old Jun 15, 2005 | 03:29 PM
90MAXGMG's Avatar
Originally Posted by TheBigDu
I'm with this dude
Old Jun 15, 2005 | 03:32 PM
Igor911's Avatar
ummm YOU DO NOT CONNECT IT TO THE YELLOW WIRE. It connects to the power antenna wire from the radio harness to the aftermarket harness.
If its connected to yellow, that means your antenna has power ALL the time. If it's connected to the power antenna wire, it only gets power when the AM/FM is being used.
Old Jun 15, 2005 | 05:09 PM
unrealii's Avatar
this keeps getting better...
chisam14
Nov 6, 2018 08:56 PM
Rungi
Aug 31, 2002 05:21 PM
