Need help wiring my system and choosing an amp
Old May 17, 2001 | 03:42 AM
Daddy Fat Sacks's Avatar
I am getting 3 12" nakamichi subs. They are 200w rms/400w peak @ 4 ohms. I plan to wire them in parallel. I think this means they will play 600w rms @ 1.33ohms...correct me if i'm wrong. Does this mean that I will need an amp that will give 600w rms x1 @ 1 ohm?? I know the amp will have to be stable to 1 ohm, but i'm not sure how much power I will need. For example, if i buy a rockford fosgate 500.2 amp... 125x2 or 500x1 bridged @ 4ohms...will that work? Or do I need to get a monoblock amp that is stable to 1 ohm? Can you give me suggestions on amps I could use that aren't too expensive?
Old May 17, 2001 | 04:35 AM
Micah95GLE's Avatar
That RF amp won't work for that load. You'd need either a two-channel amp that's 1/2-ohm stable or a mono amp that's 1- or 1.33-ohm stable. Mmats makes an amp that's 1.33-ohm stable.
Old May 17, 2001 | 05:32 AM
Dustyroads's Avatar
I don't know if this is another option, but if you could get the subs with a different load, then you could swing a different amp. I don't know if Nak makes their subs in the 12ohm variety, but but 3-12ohms wired in parallel will yield a 4ohm load, or even 3-6ohms wired in parallel will yield a 2ohm load. Finding an amp that is stable at 2ohms is much easier than finding an amp that's stable at 1ohm. This is just a suggestion and I don't even know if you can do it, but I wanted to put it out there for you. If you could even get 3-8ohms which most companies do make, then you could get down to a 2.66ohm load. Hope this helps!!
Old May 17, 2001 | 06:33 AM
That's a good idea. I'll have to check on that. Which mmats amp is 1.33 stable and how much is it?
Old May 17, 2001 | 01:43 PM
jashick's Avatar
3 12's?? damn.
You can already go deaf with just 2.
Old May 17, 2001 | 04:10 PM
Micah95GLE's Avatar
The Mmats D-200 H.C. is stable to 1 ohm, and is rated to put out 1200 watts at 1.3 ohms. The actual output is more, though.
Old May 19, 2001 | 10:25 PM
SWEETSOUND2001's Avatar
You absolutely do not need that ampf for the nakamichi subs..Get the mmats d200 model. It puts out 600 watts at the same load and is almost half the price of the d200hc...Plus those subs won't take twice their power handling..
Old May 20, 2001 | 08:36 PM
Thanks so much for your help...I'll see if I can find it. Do you think an audiobahn amp will do good?
Old May 21, 2001 | 05:27 PM
99niner99's Avatar
You could get a mmats amp, but those are pretty expensive, they're more for competing. If i were you, i'd get jlaudio subs cuz they have ohmage made for 3 woofer systems.
Old May 21, 2001 | 09:29 PM
SiMpLyMaXedOuT's Avatar
soundstreams are stable at 1ohm
as well..the rubicon's were at least....the rockfords amps arent really meant to be driven at 1ohm (according to the rf rep who i talked to this weekened)
Old May 21, 2001 | 09:56 PM
Actually, i just thought of a perfect, great priced amp for those subs.
JBL Power Valve model BP 600.1
Can be had on ebay for $250 or even less...
600+ watts into 1-2 ohms
Old May 22, 2001 | 05:38 AM
I'll check out the JBL and Soundstream. I found this audiobahn a275hcx...puts out 600x1 @ 1ohm...$273 at usacaraudio.com...what do you guys think?
DJLAX152
May 4, 2021 11:46 AM
9aj9
Apr 5, 2020 12:11 AM
popdedop
Sep 11, 2015 11:17 AM
carid
Sep 9, 2015 05:06 AM
