About stereo not working...I need help big time
Old Jun 9, 2005 | 02:27 PM
1swtMaxima's Avatar
Okay, My Cd player in my car was working fine and then it stopped. It is not getting any power but all the wires are hooked up right and everything. What could it be it wont even come on now.
Old Jun 9, 2005 | 03:26 PM
AscendantMax's Avatar
check your fuses.
btw your sig's way too big...might wanna remove one of those pics before mods get on your case.
Old Jun 9, 2005 | 04:18 PM
1swtMaxima's Avatar
i checked the fuses nothin is blown
Old Jun 9, 2005 | 05:47 PM
Dohcser's Avatar
If you have a Multi Meter ensure you are getting voltage to the harness right as it enters the HU. Also ensure you ground is secure. Make sure if it is an aftermarket HU the ground is tied directly to the chassis.
Old Jun 10, 2005 | 06:12 AM
Big_Ham's Avatar
MaximaFreak
Don't forget ... 99% of aftermarket headunits have a tube fuse in line with the power (usually yellow) wire. Make sure you check that in addition to the above suggestions.
Old Jun 10, 2005 | 09:39 PM
Torgus's Avatar
obviously everything is not right.
get a multimeter.
then find out if it's getting power.
if it's not check where the wire gets power from and keep tracing it back through fuses etc...
Check your ground as well...
if it is getting power + a good ground and it still doesn't turn on go and get it looked at, repaired, or buy a new one....
you said you checked the fuse....which one?
your multimeter will tell all.
Matt93SE
May 24, 2019 02:58 PM
trasmadean
Feb 1, 2017 08:20 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
