Installing Subs in Bose stock system
Old Jun 19, 2005 | 06:01 PM
goldtooth's Avatar
I have Bose as my stock audio system. I want to install a ECLIPSE 12" sub or 2. What would i need for a clean install and for the sub to hit right? I would be using the stock Headunit from Bose.
Any ideas or comments appreciated. Also, my experience with car audio is very minimal but I am very mechanically inclined and could follow directions quite easily(if that helps) Thanks in advance.
Old Jun 19, 2005 | 07:29 PM
fstbusa's Avatar
need some type of wiring kit to power the amp and some rcas to run the amp. Get a nissan wiring harness that converts speaker level outs to pre-amp outputs so you can hook up rcas to your bose headunit. Your bose headunit doesn't put out alot of watts at low volume so it won't hit real hard at low volume but crank it up and it bumps great.
Old Jun 20, 2005 | 12:12 AM
anton9881's Avatar
Or you can do what I did and just splice into the Rear speaker wire and run your subs off that. it works great
Old Jun 20, 2005 | 07:09 AM
f550maranello2's Avatar
I wouldnt say it sounds great.... basically whats gonna happen is the bass is going to flat line real fast... about half way up its not gonna get any louder
Old Jun 20, 2005 | 04:15 PM
goldtooth's Avatar
Sorry for being such a newb but what would be the best way to install subs for them to sound good with BOSE headunit and speakers ?
Old Jun 21, 2005 | 07:48 AM
goldtooth's Avatar
can anyone link me to what i would need to hook up subs to the BOSE headunit and speakers ?
Old Jun 21, 2005 | 08:27 AM
studman's Avatar
http://www.affsave.com/pac5.htm
You'll need the PAC AOEM-NIS2 kit. It will not require modifying the stock harness at all, and will give you 4 RCA outputs out of the stock Bose HU.
If you have additional questions, read the Audio FAQs. This question has been answered many many times over.
rbuswell
Nov 12, 2016 04:11 PM
melteye
May 16, 2016 12:02 AM
vybz05
Dec 10, 2015 07:38 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
