95 max gle bose head unit display problem.
Old Jun 26, 2005 | 09:00 AM
rcmarty's Avatar
Having problems with my bose HU. The display comes on for about 15 seconds then fades out. Just started to do it the other day. I just put in sirius sat radio but it's the re-broadcast to fm radio, so no problems there unless the use of the cig lighter is related.
Any help appreaciated.
MArtin
Old Jun 26, 2005 | 09:31 AM
ionpcs's Avatar
http://madchef.5u.com/maxima/bose/fixes.html
Here you go buddy.
Old Jun 26, 2005 | 09:53 AM
memphis_sktr's Avatar
Another thing that was wrong on the display circuit board of my bose was a couple of the leads on the male end of the connectors were not soldered all the way on to the pad, so I resoldered it on there and now it is fine! When putting the bose back together, anytime you deal with connectors, gently slide the connectors together. If you don't, you could bend one of the pins like I did. You can easily bend it right back.
Old Jun 26, 2005 | 10:27 AM
rcmarty's Avatar
Thanks for the reply's guys ,
I knew the org could hook me up
Now i need to get busy.
Maby while i'm in there i'll put some inputs in for the sat radio
Martin
Old Jun 26, 2005 | 02:08 PM
rcmarty's Avatar
Done
loose solder joint on the board just like the website says.
Now to fix the ashtray. I guess i didn't pull straight enough on the ashtray (those clips are in there good) ended up breaking both tabs off the back But i'll glue it up and add a faew tywraps for strength.
Thanks guys , much appreciated.
Martin
Old Jan 17, 2009 | 10:14 PM
v_c@yahoo.com's Avatar
Warning!
If you take the radio out, in the process you will probably blow out the light bulbs in your hazard switch and AC control panel. Parts at Radio Shack (272-1092). Buy 3 packages and return whatever you don't use. You also might screw up the reception quality and add some noise you probably didn't have before.
I took out the radio, soldered the resistor, replaced the lamps in the hazard switch and AC controller and it was a pain in the ***. If I had know of all the secondary problems, I might have been more content with losing the display.
Consider this before proceeding.
homeyclaus
Sep 3, 2015 06:15 PM
Hailstatejig
Sep 2, 2015 06:52 AM
A32goldylocks
Sep 2, 2015 06:39 AM
