Post your SPL #"s
Old Jul 7, 2005 | 05:25 PM
  #41
plurco's Avatar
Originally Posted by Maximeltman
So, 161.7 exactly? I'm psychic.
Sounds like a sweet setup though!
I had 2 18 kickers in my 89 cutlass, never had it measured, but...dammmm. I loved my 18s.
I don't remember the exact score. It was a 161.X. I mentioned it on the last page.
Old Jul 7, 2005 | 09:03 PM
  #42
2 Da Max's Avatar
wow 161?? shiet, what you do with that setup? you put it in the max?
Old Jul 8, 2005 | 08:06 AM
  #43
filtor1's Avatar
Originally Posted by plurco
I guess you have never heard of a bandpass crossover.
Nagative. Hook me up. I enjoy learning.
Old Jul 8, 2005 | 08:09 AM
  #44
filtor1's Avatar
A single Concept CSP 18 with quad 1ohm voice coils, run off of 4 Concept CCD2400 2400 watt class D amps. It was walled off in a CRX with around 10 ft^3 air space and about a 150 in^2 of port area.
The thought of this set up makes me moist...you know......down there.
Old Jul 8, 2005 | 08:12 AM
  #45
filtor1's Avatar
Originally Posted by kcidmil
Hmm, I should take bets to see what this setup would hit
4 Memphis M-Class 12"
500 watts @ 2 ohms.
And before anyone says it... yes that's underpowered. I'm getting the new MC1100D here in a month or so. 1100 watts @ 1ohm... the subs are already wired up for it.
Ok... so who wants to make the first one...
119db, port wars.
J/k. I think you would do very well. As stated before, it depends on the mic and competition perameters.
Old Jul 8, 2005 | 08:14 AM
  #46
filtor1's Avatar
Originally Posted by kpr10is
2000 watts of Lanzar power! lol
I think it was that box that did it.
kcidmil, sorry my bad, typo. And I doubt it was a new TL, come on, theyre Punch Zs, lol. Sorry, ill never have a good opinion of them thanks to the one kid i knew with two of the tens that sounded like ****. I wish I had a truck or SUV to play with as an SPL car....(hint filtor1 )
Yep, as soon as I find the money tree. I will let you know, and we can start the build. That project may have to wait till I get done with school.
Old Jul 8, 2005 | 11:01 AM
  #47
joebangaa's Avatar
jigg, i easily can believe you hit low 140s, in fact i think you can hit even higher if you fiddle around with the environment.
146 on two 12" SEALED punch z's? gotta call BS on that one. maybe 20db off lol
i've never had my stuff metered but i've been in multiple 140db cars and i'm pretty confident my two ten inch buggers can break 140 (at least with windows cracked) but maybe not on a new TL, probably something like an AC...
Old Jul 8, 2005 | 11:14 AM
  #48
Jinni's Avatar
Wookie
Where can you go to find out what your putting out? I have 2 15" kicker comps in a single ported box, and my amp pretty much sucks (it's the same amp I was using to push my 2 10" RF P1s) but I am going to get another amp and I don't know where to go to see how many db I'm pushing ........
Old Jul 8, 2005 | 11:49 AM
  #49
filtor1's Avatar
Jinni, look in the paper for local comps. You can also try calling around to area shops and see if they have a meter. Some shops are very cool about it, others, well, suck. I would love to see what they would do! Let us know if you get it metered.
Old Jul 8, 2005 | 12:49 PM
  #50
kcidmil's Avatar
Easy to do when you're running everything in a truck. The subs are right there. The guy who won the comp hit 150.1 Running 2 JL subs in a custom vented box.
There was a Navi there that needed a lot of help though. 6 12"s with 2 1000 watt amps. He only hit 147.8... that was freaking hilarious. His roof was flexing, and he had guys holding his back hatch closed. He even tried flooring it at the end to keep the amps charged.
And like it was stated before, that was not on the new TL mics.
Old Jul 8, 2005 | 01:14 PM
  #51
Chitwista's Avatar
My best to date is a 142.1 w/ 2 - 12" MTX 9500 Series Subs.. Powered by a MTX 1501d Amp..
Old Jul 8, 2005 | 02:08 PM
  #52
quiksand's Avatar
Bandpass Filter - is a Low Pass and a High Pass filter. All frequencies between the High and Low pass are allowed through. Ideal for midbass speakers. Kicker used to sell a passive one, the frequency range allowed on that was 100hz - 350hz. It was their MB-100 crossover. I still have em in my closet.
Im sure you knew that and was being sarcastic. Just info for those that may not know.
Old Jul 8, 2005 | 02:21 PM
  #53
plurco's Avatar
thank you for doing my dirty work
Old Jul 8, 2005 | 02:32 PM
  #54
jigga123's Avatar
I learned something!
Old Jul 8, 2005 | 05:11 PM
  #55
joebangaa's Avatar
dude i looked at your sig and i thought, oh he runs 13's cool, he must have headers...check your cardomain to see you have a freakin wet shot setup lol. i'd like to hit 13's NA and post 140s legal (of course this may be possible as i'm probably getting two rl-ps...and porting them
Old Jul 8, 2005 | 05:23 PM
  #56
filtor1's Avatar
Unfortunately I was not. I knew that was a type of X-over, but hadn't heard it called that. Thanks for the extra tid bit of knowledge.
Old Jul 8, 2005 | 09:13 PM
  #57
505max94se's Avatar
Bandpass and SQ shouldn't be in the sentence.
If you look at it again, bandpass and sq aren't in the same sentence. They're in the same post. jk
Bandpass isn't usually associated with sq at all but in my case it is. I've had the same sub in a large custom sealed box on the same amp and it sounds ALOT better in the bandpass.
The box isn't your average bandpass. It has fiberglass on the inside to help smooth out the air flowing through the port (it's not in the corners, it's a v-shape piece that's directly in front of the sub). It's also tuned pretty low (35 hz). For some reason it just plays everything very accurate.
sub= (
fiberglass= <
wood= |
Port= =
I've heard ALOT of system's out there and I haven't heard cleaner bass than mine. I've heard louder but not cleaner and ALOT of people think the same thing. My best friend is the shop manager/installer at the largest/best audio shop in the state. I know my ****.
Old Jul 8, 2005 | 09:34 PM
  #58
505max94se's Avatar
Now that I think of it, the only bass that I've heard that's a little cleaner is my friends two 10 in. jl w6 v2's in a sealed box powered by a us amps tu-600 class-a tube amp (300x2)
Old Jul 9, 2005 | 02:24 PM
  #59
ShRapNeR's Avatar
96 max gxe
stock alt
yellow top battery
big 3 w/ hyper ground
4g pwr and grnd
hifonics brutus 1800d
RE 15"XXX
3.75ft^3 tuned to 35hz
new TL was on the windshield
windows up
139.6
was hoping for more
Old Jul 9, 2005 | 02:51 PM
  #60
Pearl96Max's Avatar
I tend to get a bit irritable
Chris, just go play with Jeremys DXE, its in there for the X2 and X3 spots. WHich I set for him WITH YOU. Dont remember things at 3am 2K miles away?
Old Jul 9, 2005 | 06:35 PM
  #61
Wil's95SE's Avatar
我爱台湾
The audio shop I go to sponsors 2 vehicles ( a old school Integra, and a Yota tacoma ), both which have easily metered at 155db+, not on the new TL but am willing to see what they would do on that. I've never tested my 2 10's but believe they could easily be close if not break 140db with no problems.
Old Jul 9, 2005 | 06:53 PM
  #62
AscendantMax's Avatar
what 10s are you running? box and power?
Old Jul 9, 2005 | 08:14 PM
  #63
filtor1's Avatar
Neg. My mind only works for around 3 hrs/day. It had shut off well before the 2-3am tuning session. If I can pull him away from his new GF I def would. He seems to be a bit occupied as of late. Guess I just have to save my pennies and get my own to play with.
Old Jul 9, 2005 | 08:50 PM
  #64
joebangaa's Avatar
dont know about him but the boomers in my sig for sale should be able to do the same in burps w/ test tones (probably doesnt show, L5's in 3.5ft^3~34hz)...not much for sq but for a ghetto street beater it's more than enough
Old Jul 9, 2005 | 09:05 PM
  #65
what sig?
Old Jul 9, 2005 | 09:09 PM
  #66
kpr10is's Avatar
what sig?
Check page 2...posting multiple times in one thread will usually only make your sig only show up on your first post. Newb
(at least thats what ive noticed...not 100% sure)
Old Jul 9, 2005 | 09:29 PM
  #67
nope, it's 1 sig per page newb
(i think )
Old Jul 9, 2005 | 09:33 PM
  #68
kpr10is's Avatar
But that was ighettoboy's first post on page 3 and his sig didnt show up
don will chime in eventually and enlighten us
Old Jul 9, 2005 | 09:53 PM
  #69
Pearl96Max's Avatar
1 sig per page. IF you choose to "show signature"
Old Jul 9, 2005 | 09:57 PM
  #70
kpr10is's Avatar
learn something everyday
Old Jul 10, 2005 | 06:34 AM
  #71
joebangaa's Avatar
i'm pretty sure i did choose. anyhow, like i said, solo 10" L5's in a box sized for twelves...
Old Jul 18, 2005 | 01:37 PM
  #72
Ammi's Avatar
350 Detroit Muscle
what songs were you guys playing when measuring db???
Old Jul 18, 2005 | 01:44 PM
  #73
plurco's Avatar
I used a 65hz tone.
Old Jul 18, 2005 | 02:37 PM
  #74
kinitaro's Avatar
my average is about 138-140 but i peak at about 147
00 Nissan Maxima.
its the dB display off of my Epic 150
Old Jul 18, 2005 | 04:19 PM
  #75
joebangaa's Avatar
^^ what the heck do you have in the trunk...
Old Jul 18, 2005 | 04:52 PM
  #76
Lytheum's Avatar
I hit 139.9 on the term lab.
12" Brahma
Hifionics Brutus 1500d
2 cube box ported at 25hz
i was just playing some three six mafia song. i think i could get louder with a test tone.
Old Jul 18, 2005 | 06:16 PM
  #77
kinitaro's Avatar
Eclipse CD5442
Eclipse 5-1/4" component speakers w/ 1" tweeters
Eclipse 6-1/2" 2-way component speakers
Subs Woofers: Dual Eclipse 12" 4 ohm Subwoofers
Sub Amp: Kicker KX600.1
Speaker Amp: Kicker KX650.4
AudioControl Epic 150
Tsunami 10 Farrad Cap
custom fiberglased enclosure (sealed)
and i ported my trunk to allow more air flow without having to pull down my seats.
Old Jul 18, 2005 | 07:03 PM
  #78
joebangaa's Avatar
12" Brahma
very solid score there
Originally Posted by kinitaro
Eclipse CD5442
you're telling me your two SEALED 12"s given 600w @ 2ohm total is really doing 147 db??? i know audiocontrols aren't like termlab sensors but i'm gonna have to say you need a new mic or BS.
Old Jul 18, 2005 | 07:06 PM
  #79
12" Brahma
brahma =
i still miss mine
Old Jul 18, 2005 | 07:13 PM
  #80
joebangaa's Avatar
how's the AVA workin out for ya? got a 12 or 15"?
