XM Radio wont keep Station Presets
Old 07-10-2005 | 12:49 PM
bigleman's Avatar
Advocatus Diaboli
Head Unit: Pioneer DVH-P5000MP
XM Unit: TERK Pioneer XM adapter and Tuner
Problem: Before i moved everything from the Maxima into my new car, it was working fine, and working fine while it was in the new car for a while. Well i was installing the LCD screen and the big plug that goes to the tuner from the headunit got f'ed up. Glad i bought the service plan... I went and got a new adapter. Well i pluged everything back up and now it wont keep the station presets. I get it to the station i want, press and hold the number button, it beeps but it still stores it as station 001. I emailed Pioneer, they said it was a problem with the TERK unit, i emaild TERK, they said it was a problem with my Pioneer unit, so F*** them...
Anyone have any clues?
Old 07-10-2005 | 01:11 PM
luckyprettyeyes's Avatar
I don't know what to tell you kid Sometimes things just break. I really love your gauges though...so I had to leave a pointless comment. Where did you get them?
Old 07-10-2005 | 01:41 PM
bigleman's Avatar
Advocatus Diaboli
i refuse to believe that it just doesnt work...
www.importintelligence.com
Old 07-10-2005 | 01:45 PM
Pearl96Max's Avatar
I tend to get a bit irritable
You most likely just dont have your constant power wire hooked up correctly.
Old 07-22-2005 | 06:47 AM
silversurfersg's Avatar
i think i read its because ur timezone setting arent set right. look around, maybe siriusbackstage.com
Old 07-22-2005 | 03:29 PM
CreativeDesignz's Avatar
i would go with what don said...same thing happened to someone that came into my shop today.
Old 07-22-2005 | 04:09 PM
plurco's Avatar
Yeah, if you have your constant and switched wires backwards, this would happen.
Old 07-22-2005 | 11:41 PM
kpr10is's Avatar
+1. Pioneer add-ons like that get their switched power through the IP BUS cable, so whether its an ipod adapter, xm, sirius...wire it to constant, not switched. If that doesnt solve it, its the Terk box. Ive seen almost as many of the Pioneer Terk XM boxes come back with problems as we've sold since we started carrying them.
Old 07-25-2005 | 06:39 PM
gumbyandpokie99's Avatar
Perhaps the Constant power connection (yellow)either in the connector or the Solder joint inside the xm tuner is weak and could be intermittently working.Leaving you with no presets.
Old 07-25-2005 | 09:45 PM
bigleman's Avatar
Advocatus Diaboli
would the sat radio still work if the main power was disconnected. Would it be able to get the power from the head to run? I may have popped a fuse, thats a goo thing to check, thanks all!!
gavin68
09-18-2021 12:36 PM
chisam14
11-06-2018 08:56 PM
mikeg75
11-30-2015 05:12 PM
Max Nu-BE
09-28-2015 10:25 AM
Quick Reply: XM Radio wont keep Station Presets
