Two bulges on side of trunk ... wheel well?
Old Jul 12, 2005 | 08:23 AM
Big_Ham's Avatar
MaximaFreak
Simple question, but I need to make sure/double check.
The bulges on the side of the 5.5 gen trunk ... that is the wheel well, correct? If I put a drill bit though it, I only need to be concerned with what's visible from the wheel well, correct? I'm assuming there's nothing in between there I cannot see.
Old Jul 12, 2005 | 10:56 AM
djfrestyl's Avatar
Suspension Yoda
yes, those are the wheel wells
pull away the protective layer on the inside of the wheel well (its like a plastic/cardboard piece) and you'll see the underside of that bulge
Old Jul 12, 2005 | 05:14 PM
filtor1's Avatar
Why the hell are you drilling the wheel wells?
Old Jul 12, 2005 | 05:19 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Old Jul 12, 2005 | 05:36 PM
Big_Ham's Avatar
MaximaFreak
You'll see, Daniel-son, you'll see.
Old Jul 12, 2005 | 05:38 PM
Hrmmm...my interest is most certainley piqued.
Old Jul 12, 2005 | 05:49 PM
filtor1's Avatar
10characters
Old Jul 12, 2005 | 07:19 PM
Big_Ham's Avatar
MaximaFreak
Well, to be honest, I'm not sure what I'm going to do. But I have lots of ideas around floating amps.
Old Jul 13, 2005 | 05:06 AM
djfrestyl's Avatar
Suspension Yoda
my thoughts were:
a: for mounting purposes - of whatever, false walls, amp, amp racks, etc
b: ground, anyone? that was my first theory
Old Jul 13, 2005 | 06:33 AM
Big_Ham's Avatar
MaximaFreak
Actually ... that's a fantastic grounding point. Enables you to put a nut and bolt through the O ring with some loctite after sanding and keep it hidden behind the factory trunk liner. Might be a good thing to put in a FAQ?
Old Jul 13, 2005 | 06:38 AM
djfrestyl's Avatar
Suspension Yoda
through the O ring implying there already is one? or through an o ring, implying u gotta get one with the bolts? i wasnt aware of one so i shall assume the latter....
Old Jul 13, 2005 | 07:01 AM
Big_Ham's Avatar
MaximaFreak
Crimp style O rings are typically used for grounding cables ... sorry if I confused you by inferring there was already one.
Old Jul 13, 2005 | 07:06 AM
djfrestyl's Avatar
Suspension Yoda
OH ure talking about the ring terminal for the wire..yea those im well aware of
i thought u were talking about a rubber one for some reason..located in that general area that covers an existing hole, or something of that nature
Old Jul 13, 2005 | 07:43 AM
Big_Ham's Avatar
MaximaFreak
FYI - Those are typically referred to as grommets.
Old Jul 13, 2005 | 07:45 AM
djfrestyl's Avatar
Suspension Yoda
yes i know
brain fart i guess
Old Jul 13, 2005 | 08:40 AM
filtor1's Avatar
On the drivers side of the trunk, there is a round rubber grommet. I fed my ground wires through there and attatched them to a bolt under the car. It's hidden and I didn't have to drill. Just an option.
Old Jul 13, 2005 | 06:13 PM
snair2's Avatar
Wait, I don't understand, you attached the bolt through the hole for the grommet, and this hole was big enough for the bolt to hold on? I'm having a hard time visualizing this (never seen the grommet).
Did hooking the ground up to that particular area eliminate any engine whine? I need to try something out to fix my engine whine...
Old Jul 13, 2005 | 07:04 PM
Big_Ham's Avatar
MaximaFreak
Hope you sealed that up with some paint or rubberized undercoating.
You know, I'm looking into having my trunk shot with bedliner ... should be a killer sound deadener ...
Old Jul 14, 2005 | 01:14 AM
trebor317's Avatar
hey will that really work?? i was lookin at dynomat stuff the other day and my dad suggested i should just have it sprayed with bedliner i said ok but i didnt really tyhink it would work but would it???
Old Jul 14, 2005 | 04:30 AM
Big_Ham's Avatar
MaximaFreak
Absolutely. All any sound deadener does is add weight to metal to reduce resonant frequencies. If you wanted, you could strip your entire interior and have them spray the entire inside of the car. Wouldn't be cheap, but your car would ride like a Lexus.
Old Jul 14, 2005 | 09:39 AM
filtor1's Avatar
I wish I had my computer back, I have an insane # of pics to show. The wire is just run through the gromet. The bolt is the mounting bolt to the carbon pellet filled square container(something to do with the fuel lines and the vapors, emissions BS). All I did was add a connector to the end of the wires, -0, and rescrew the bolt into the factory location. The ground wire extends abour 6" after the gromet to reach the bolt.
I don't think you have the gromet in your 4th gen. 5th gens do though.
Old Jul 14, 2005 | 09:42 AM
filtor1's Avatar
There is other purposes for deadner, it also acts as a barrier to keep unwanted sounds, ie road noise, out and keep the music inside. This is where I think the spray on bed liner would fail due to it's thickness. JMO.
Old Jul 14, 2005 | 09:53 AM
Big_Ham's Avatar
MaximaFreak
Spray on bedliners can be as thick as you want. When you go to the place you will specify it's for sound deadening and they 1. will have a different way to mix it, or 2. will apply more coats than they would to the bed of a truck. Either way, the difference would definitely be noticable, I can promise you that.
Now ... my only question is about cost effectiveness as everything on the internet points to it being $300 or so to do the bed of a truck ... I wonder how much they would charge to do the trunk of a car.
Old Jul 14, 2005 | 10:00 AM
filtor1's Avatar
Probably less $. I also wonder about the smell. I know it smell in the bed of a truck for a while.
Old Jul 14, 2005 | 10:02 AM
Big_Ham's Avatar
MaximaFreak
Holy ****. Just called Line-X in Clearwater to get a quote ... $500. Looks like it's DIY or empty your pockets ...
Oh and ... most, if not all, spray sound deadeners smell at least a little bit ...
Old Jul 14, 2005 | 01:29 PM
filtor1's Avatar
If you can stand the smell then go for it. I say buy some deadner and invite some friends over and go at it. I would be willing to shoot down for the day and bang out some deadener if you went that route.
$500 is crazy. Especially if it was going to smell.
Old Jul 14, 2005 | 01:43 PM
Big_Ham's Avatar
MaximaFreak
$500 is more than crazy ... you'd have to have a labotomy to do that.
Anyway ... I think the spray route is in my forseeable future. There are lots of nice products out there. It will just take time to mask everything off and make sure you don't paint the car itself in the meantime ... YIKES.
Old Jul 14, 2005 | 02:41 PM
ionpcs's Avatar
I hear you're supposed to use a paintbrush, not a spray action, for the liquid deadener... just a thought.
Old Jul 14, 2005 | 10:48 PM
Big_Ham's Avatar
MaximaFreak
There is the kind you roll on and then there is also aerosol type spray. This is the most versatile way to do it. When you spray your door panels, it's easier to get a good coat on the outer door skin as well.
Old Aug 5, 2005 | 01:09 PM
sickmax's Avatar
aaron lavigne FTG
i had that done in my GTI tht i had before my maxima. It was the best sound dedener i have used. You could have ur music LOUd and as long as all the windows were up you could barly hear it on the outside
Old Aug 5, 2005 | 01:24 PM
luigi'smax's Avatar
pics ??
luigi
Old Aug 5, 2005 | 02:50 PM
Originally Posted by luigi'smax
pics ??
luigi
trasmadean
Feb 1, 2017 08:20 PM
vingodine
45
May 21, 2016 12:46 PM
Roman777NYC
Nov 7, 2015 10:13 PM
Former3G
Oct 26, 2015 11:34 PM
Balkins
Aug 12, 2015 06:39 AM
