Don please help LOL
Old Jul 12, 2005 | 07:02 PM
99 SE-L
Don please help LOL
Hey man iam having problems with whine I currently have a Alpine headunit/2 amps -1 PG 2Ch/1 PG mono Connected by a distribution block i got a reall ybad alternator whine, also when the second amp got hooked up iam gettign whine even when the radio is turned off , i even took of the faceplate to ensure the radio is off any ideas i wanna finish but the whine is gettign to me is there any way to test if its the amp thanks ...
Old Jul 12, 2005 | 07:12 PM
sk24iam's Avatar
Check all your grounds.
Old Jul 12, 2005 | 07:17 PM
99 SE-L
checked....
Old Jul 12, 2005 | 07:29 PM
jigga123's Avatar
Are both amps grounded to the same point? Ground both to the same points and see if that changes anything. Also, were did you run the RCA's. Disconnect the RCA's(with all power off) and turn everything back on and see if it goes away. Another problem could be your HU ground, is it grounded to the car itself? Try doing these things and see if you can decipher were the problem is.
Old Jul 12, 2005 | 07:32 PM
AscendantMax's Avatar
shouldn't matter where he ran his RCA's...
Old Jul 12, 2005 | 07:52 PM
jigga123's Avatar
It doenst most of the time, still a possibility though. It could be a bad plug on the RCA's, happened to me before.
Old Jul 12, 2005 | 08:04 PM
2 Da Max's Avatar
if its not your grounds, then you need a new altenator. a se max should have 110 amps
Old Jul 12, 2005 | 08:38 PM
CreativeDesignz's Avatar
i thought se's has 125...my I30 has 125
Old Jul 12, 2005 | 08:56 PM
Igor911's Avatar
I can sell you something that will stop it. $25 and it's yours. I'm leaving for vacation tom. morning. Will be back fri night
$25 installed.
Old Jul 12, 2005 | 08:58 PM
Igor911's Avatar
yes it does, RCA's need to be run on a different side than the power is ran.
Old Jul 12, 2005 | 09:17 PM
Trevmister1610's Avatar
that statement is true and untrue, if u have cheap rca cables and cheap power wires , then your rca cables might pick up feedback from the power wires, but if u have nice rca cables and nice power wire, then this shouldnt be a problem, it all depends what types of insulators the company uses.
i had this problem with my car getting the alternator noise, make sure u have sanded the paint around the grounds, that was my problem
Old Jul 12, 2005 | 09:28 PM
Igor911's Avatar
trust me, this kid buys the cheapest crap and I guarantee you his grounds suck.
Old Jul 12, 2005 | 09:31 PM
that's a common myth. it doesn't need to be seperated. the rca's won't pick up any noise from the power cable (unless they're horrid quality). i have all my wires running down one side of the car for simplicity and have no noises what so ever.
Old Jul 12, 2005 | 09:38 PM
f550maranello2's Avatar
dude you dont know what you are talking about.... if you run a RCA wire next to the power wires it might pick up feedback... it all depends on the insulation... i have seen the best wiring pick up nasty feedback because someone ran them too closely....
Old Jul 12, 2005 | 09:47 PM
Igor911's Avatar
I got alot of my knowledge on this stuff from actual experience and 12volt.com
Old Jul 12, 2005 | 10:10 PM
mendon99's Avatar
tastey wheat
might one of the amps. PG is short for what? maybe im just blanking... i had a pos fosgate amp once and it had really bad alternator whine, switched amps and it was gone....
Old Jul 13, 2005 | 07:36 AM
jigga123's Avatar
I think the RCA's really depend on the quality of it. If its cheapo Walmart RCA's it oculd be there that your problem lies. He hasn't responded so maybe it was fixed already.
Old Jul 13, 2005 | 08:00 AM
djfrestyl's Avatar
Suspension Yoda
holy batman! another thread about running power and RCA next to each other!
Old Jul 13, 2005 | 11:03 AM
99 SE-L
Igor are you stupid my RCA are Monster and Stinger and i dont think the thign you got will help i think it called noise supressor its the 2 Ch amp i think
Old Jul 13, 2005 | 01:55 PM
Big_Ham's Avatar
MaximaFreak
Dood ... check your ground AGAIN. Reground your battery and alternator with thicker wires, and make sure your ground wire is as thick as the power wire that runs to the back of the car.
Grounds should be free of wiggle room, rust, paint, dirt, etc. If you STILL have alternator whine, it could be coming from a loose RCA connector on your amp or outboard crossover or just a bad piece of equipment in general.
Old Jul 13, 2005 | 01:58 PM
2 Da Max's Avatar
hhm wait till Friendhasmax comes on.. flamefest
Old Jul 13, 2005 | 02:02 PM
kpr10is's Avatar
Old Jul 13, 2005 | 06:12 PM
99 SE-L
My RCA'S are ran on my passenger side,power wires ran on drivers....
Old Jul 13, 2005 | 10:27 PM
if u read what i said, i said that it all depends on the insulation, but i did spell insulation wrong
Old Jul 14, 2005 | 06:17 AM
djfrestyl's Avatar
Suspension Yoda
spell check is your friend. its right.
Old Jul 14, 2005 | 08:15 AM
MannyNJ2k2max's Avatar
http://www.crutchfield.com/S-TOMUV4D...rch=alternator
http://www.crutchfieldadvisor.com/S-...car/noise.html
http://www.crutchfieldadvisor.com/S-..._diagnose.html
Old Jul 14, 2005 | 11:57 AM
99 SE-L
Thanks alot manny
Old Jul 14, 2005 | 12:13 PM
99 SE-L
[Well either its a bad amp or a bad Alternator
Old Jul 14, 2005 | 12:14 PM
Thanks alot manny
very welcome- good luck
captchaos
Mar 15, 2016 12:18 PM
rnb754
Sep 14, 2015 11:39 PM
pjgreek
Sep 9, 2015 09:30 PM
Violator
Sep 9, 2015 10:14 AM
JoshG
Sep 5, 2015 10:10 PM
