ohms of amp?
Old Jul 18, 2005 | 12:04 PM
dayglo's Avatar
ohms of amp?
im looking for a new amp..but some dont even list what ohms they're stable to. does this mean that theyre stable to any?
i have a 900w 12" visonik 4ohm single VC
i dont know what amp specs i should be looking for...the last system i had worked fine, regardles of me knowing any specs like this.
im looking at ;
Amplifier Output Details 300 Watt - 2 channel(s) Â
600 Watt - 1 channel(s)
active crossover, Gold plated connectors, thermal protection, overload protection, short circuit protection.
if my sub is 4ohms, will any amp work??
if not then i dont know how to tell if this amp is 40hm stable.
this sucks!
thanks alot for any help
Old Jul 18, 2005 | 12:14 PM
BBOYSTEVIE's Avatar
Back from Hibernation
sounds like a typical 2 channel amp that "allegedly" doubles power at 4 ohms mono or two ohms stereo....in which case my answer would be yes.
I guess I'd say that I don't know of a car audio amp that isn't 4 ohm stable, but you'd of course wanna make sure you're getting the max power the amp was designed for. (like you wouldn't want to get a typical type Class D sub amp that puts out max power at 1 ohm mono, cause you would't see jack at 4 ohms mono.
Got a name and model number/link to the amp?
Old Jul 18, 2005 | 12:20 PM
dayglo's Avatar
http://www.londondrugs.com/Cultures/...9&ProductTab=1
i know it's not very high end but i dont want to spend alot
thanks for the help though. i had a hunch that most amps can handle 4ohms because it was standard or somehting. i dont know anything though.
also i just want to bridge this sub. if that makes a differance?
Old Jul 18, 2005 | 12:44 PM
BBOYSTEVIE's Avatar
Actually, you're bridging the amp...to run mono...to the one channel (speaker) your running.
Resisting temptation to steer you towards other amps......but I will say this.....There is no regulations as to how amps are rated/reported, so a car audio amp that claims to put out 500,,1000, or whatever watts may not necessarily be doing so. Pyramid doesn't have the best reputation, though I must admit I haven't tried one personally.
Yes, thats a standard 2 channel amp that should be fine at 4 ohms mono. The should part has to do with the build/part quality/heat dissapation and such.
jmlee44
Oct 2, 2022 02:13 PM
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
