5th genners w/ full systems...how much wire did you use?
Old Jul 20, 2005 | 02:51 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Just as the title reads, I was wondering how much speaker wire you nukkas wound up using for your install. Comps up front, coaxes in rear. I will be using Karma Kable (12AWG) from KnuKonceptz.
Old Jul 20, 2005 | 03:05 PM
filtor1's Avatar
12' for each rear door, 18' for each front door. Each was run from the amp( in the middle of the trunk) to the rear corner-along the side(to the front corner)-the along thier respective sides-the into the doors. Maybe some over kill as far as routing, I think it was worth it.
Old Jul 20, 2005 | 05:10 PM
Thanks for the response, Chris. So you think 75ft. ought to cover it all?
Old Jul 20, 2005 | 06:04 PM
seventy5impala's Avatar
i beleive i went with 85 or so foot for my 2k max.... both front speakers, both tweeters, and rears..a little bit extra, 75 should hit it on the money but better safe than sorry... i even went off and did each speaker pair its own color so the idiot in me couldnt screw it up later....
Old Jul 20, 2005 | 06:23 PM
Igor911's Avatar
I went thru about 150 feet or so. I also used some of the wire for + and - for some accesories.
Old Jul 20, 2005 | 07:24 PM
filtor1's Avatar
Should be. I always get an extra few feet just to CMA. I say get 85 just to be sure.
Old Jul 20, 2005 | 08:45 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Typically about 80ft
Old Jul 26, 2005 | 03:04 AM
Tony Fernandes's Avatar
12 guage? How much power you plan on running through that wire?
I think I used up most of the 80 feet I purchased.
Tony
Old Jul 26, 2005 | 05:30 AM
Tony
We are not getting into this one again. I'd sooner over compensate than undercompensate any day of the year.
Old Jul 26, 2005 | 08:45 AM
MannyNJ2k2max's Avatar
i used 12 ga for my mids, 15 ga for the tweets- total amount is def different than most considering my tweeter amp is under my passengers seat. def way under 70ft total used
Old Jul 26, 2005 | 01:39 PM
Any reason you used a smaller gauge for the tweets? I know the Rainbows I have already have a tiny-azz wire soldered onto the tweet connections...so I guess I have to go smaller on those?
Old Jul 26, 2005 | 02:30 PM
I used some good Stinger scrap wire Don had laying around. Also tweets are seeing ~70rms, wheres mids have a 300 x2 amp on them. 12ga on any tweets may be overkill as far as cost is concerned, but IO cannot see it being a problem. Now if you stick to 16ga its much easier to connect via barrel connectors or male/female quick disconnect connects(what i used)
Old Jul 26, 2005 | 05:11 PM
Awesome, thanks! I am going to be soldering all of my connections to the speaker leads since I seem to be soldering all sorts of LEDs these days...
Old Jul 26, 2005 | 09:13 PM
Pearl96Max's Avatar
Just too bad I didnt have any of the 10Awg that I ran my 8s with left
Old Jul 27, 2005 | 07:52 PM
unrealii's Avatar
Thats about as much as I used. Ran 2 wires to the front on each side for each speaker and one through the rear door on each side.
Old Jul 27, 2005 | 09:02 PM
Thanks for everyone's suggestions! I wound up purchasing 75ft. of this:
14 GA. Silver Plated Kasa Kable. Probably over hyped and over priced, but I'd sooner not take my chances. It was going at $1.99 per foot, but the prices were recently dropped to $1.19/foot, so what the heck. I would have preferred the other stuff, but they are sold out until late August, but I will be doing the install by then.
Old Jul 28, 2005 | 05:40 AM
Pearl96Max's Avatar
Geeeesh Dan I coulda gave ya Stinger 12awg for that price, shoulda called me
Old Jul 28, 2005 | 06:51 AM
Kevlo911's Avatar
Kevlo for President
Instead of starting a new thread, how much wire will I need if I mount the amp in the trunk or under the rear seat? Someone told me 30ft in another thread but everyone is saying around 75ft in this one.
Old Jul 28, 2005 | 08:35 AM
30ft? nope....you need that much for the comps themselves, if not more....if you are going into the doors with it, plus you always want some slack.
Old Jul 28, 2005 | 09:01 AM
Kevlo911's Avatar
Kevlo for President
I see, so I will also get about 75ft of 12-14guage speaker wire when all my stuff comes in.
Old Aug 1, 2005 | 06:47 PM
Nomad's Avatar
kinda OFF topic but wouldn't it be easier to mount AMP for speakers under front passenger seat instead of mounting it in the trunk
Old Aug 1, 2005 | 06:54 PM
I would have, but this doesn't fit under my seat.
Old Aug 1, 2005 | 10:33 PM
djfrestyl's Avatar
Suspension Yoda
Shieet havent seen pics of that in a while. It's looking sweeeet.
Old Aug 2, 2005 | 03:48 PM
Nomad's Avatar
LOL Metal Max since you have plenty of space for few AMPs you won't mount them under the seat but being an optimist i'd mount AMP for speakers under the seat hell that's a lot of wiring going to the trunk and back.
Old Aug 4, 2005 | 11:02 AM
I gotta start calling you again.
MAXSE5SPD
Sep 17, 2022 04:00 AM
220k+ A32
Sep 23, 2015 03:38 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
