diffrence in LED and bulbs?
Old Jul 21, 2005 | 10:03 PM
TurTLe*'s Avatar
is there much diffrence in light output between wiring a LED and buying a LED bulb? lets just use a 194 for example. Would there me much light diffrence between the 2?
I know a lot of ppl use the plane LED's with resisters because they can attach more then 1 into the housing (whatever it maybe). But i'm not looking to do that. Just 1 plain LED.
Its common sense that getting a LED bulb would be easier since its plug and play but if its not as bright as a LED with a resister then i'm not going to do it.
Old Jul 23, 2005 | 04:07 AM
BK1's Avatar
BK1
Hello
The light output on LED's are directional...they only point one way. A regular bulb puts out radial light...light goes out in all directions. Some LED bulbs are upgraded to overcome this problem.
Old Jul 23, 2005 | 06:56 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Yes, there is a huge difference, but all is contingent on the type of bulb you will be using and the application. As far as using an LED with a resistor, if you are using a single LED, you will need a resistor; the use of a resistor is required as based upon the forward voltage of the LED, the amperage desired to flow to it, and the resistance needed to get that amperage. Most LEDs have a FV of 3.5V, and operate @ 20mA - combine this with the fact that you have about 13.1 or lower volts availible and it become quite apparent that resitors a necessity.
Old Jul 23, 2005 | 06:57 AM
AscendantMax's Avatar
what bk1 said, plus LEDs have practically no warm up time. bulbs have this very slight delay from on to off...if that makes any sense...
Old Jul 23, 2005 | 07:00 AM
I don't know if I would call it an upgrade, it's just a differently shaped lens.
Old Jul 25, 2005 | 09:16 AM
BK1's Avatar
BK1
Hello
I don't mess with LED's...there's something I dont like about them.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
