which speaker wires to splice on 00 max
where are the easiest acessable speaker wires to splice into to convert to rca's on an 00 max
also, where is the best spot to run the power cable thru the firewall
Originally Posted by kpr10is
Easiest place to tap into wires for the LOC then is at the Bose sub itself.
Easiest place to drill is where the clutch plate would be if it were a 5 spd.
The best way to get the power wire through the firewall and to the battery, is simply, take off the front driverside tire, pull back the wheel well liner/splash guards, and you'll see a big grommet. Pull away the grommet, and stick the power wire through and snake it to the battery. 4 gauge wire will easily go though that hole. I recommend this method as you do not have to drill into anything.
The Frye
09-02-2021 11:03 AM
