running with no rear fill
Old Jul 30, 2005 | 08:16 AM
Cumalot's Avatar
I'm not the biggest on audio. However, I really need to upgrade my factory BOSE. It keeps on blowing. I'm on my third set of BOSE speakers and second BOSE HU. I'm not going to go that route again. I already bought a set of used Eclipse components and a JL Audio 4ch. amp. I still need a HU. I don't plan to run any rear fill. First to save some money and second I'm usually by myself in the car. As far as HU, I'm thinking of going with a Pioneer HU. I want an Eclipse HU, but they are a bit too pricey. So how would a Pioneer HU, Eclipse components, and JL Audio sound? Or should I just ahead and get a rear fill too? TIA.
Old Jul 30, 2005 | 08:33 AM
maxgtr2000's Avatar
KH3 by popular demand
As long as you have a good front stage you don't really need rear fill, but that's all your preference. You could save the money and do without it, however if you are technical and want to have true 5.1 for incar video applications just get a regular set of speakers and throw them back there they don't have to be another component set. I haven't heard the eclipse components but it will be better than stock, all those you chose are good name brands that perform.
Old Jul 30, 2005 | 08:38 AM
MannyNJ2k2max's Avatar
IMO use the 2 front channels to run your components and bridge the last two for sub duty(whichever u decide- 8" in the rear deck IB, or a single 10 or 12" in an enclosure for the trunk-shouldn't take up much space. As far as HU if you are on a budget, just find one with the features/conveniences you need/use.
eh...i have coaxials sitting in my garage- just dont bother to put'm back in- i dont miss rear fill much. In real world if you were at a concert you dont have sound/vocals coming from behind you, its much more realistic and more plasurable to focus on the separation up front. Lots of people like the added sound of rear fill tho, decision you have to make.
Old Jul 30, 2005 | 08:44 AM
As far as 5.1 goes, if you are into HT having rear fill is not much fun unless you have a nice center channel anyways-4.1 aint gonna cut it...lol. Due to the encoding of DVD's you'll lose alot of volume, language and stage not having a center channel.
If you are building the car for 5.1 then do it correctly, if true music reproduction is more important, then there is really no need for fill.
Old Jul 30, 2005 | 09:20 AM
Cumalot's Avatar
I'm definitely not going to do any in-car video. I don't even plan to add a sub. If the BOSE system wasn't so bad, I would much rather keep the audio stock.
Old Jul 30, 2005 | 09:25 AM
Kevlo911's Avatar
Kevlo for President
I am gonna put these in the rear
http://www.partsexpress.com/pe/pshow...number=264-832
Some Diamond D3's in the front
A decent 4channel amp and an Eclipse HU to replace the BOSE. It should cost around 500-600.
Old Jul 30, 2005 | 09:44 AM
I wouldn't run those Eclipses' full range...most aftermarket speakers dont play well full range, or offer enough lower bass- without a sub you will find the sound flat and tiny compared to the blose which offers a bassy sound.I'd consider a sub, you have the power available for it to put together a nice sounding full range system.
Old Jul 30, 2005 | 02:38 PM
Cumalot's Avatar
So I could go with a sub, but still don't have to get any rear fill? Wouldn't that sound weird with a sub in the back, but no rear fill?
Old Jul 30, 2005 | 02:43 PM
plurco's Avatar
you just like those because they are called "tang"
Old Jul 30, 2005 | 02:47 PM
Kevlo911's Avatar
Kevlo for President
They better sound good .....
Old Jul 30, 2005 | 09:48 PM
Montypup's Avatar
I ran with a sub and no real fill for a while and it still sounds kinda weird. I ended up putting a set of infiniti references and a small alpine amp for rear fill. Sounds much better now.
Old Jul 30, 2005 | 09:58 PM
BBOYSTEVIE's Avatar
Back from Hibernation
When you go to a concert, do you turn around so the music comes from behind you? Of course not. Establish a front stage that presents the music in front of you as it should appear on the soundstage, as if you WERE in concert and the band was coming in front of you, or at least you hear the music as the musicians meant it to be heard. Video is surriound w/ center channel. Audio is stereo, left and right channel in front of you only. #%*@ rear fill. Once you hear music the way it's supposed to be heard, you'll never go back!
Sorry to rant...it's not about needing rear fill or not....I'm obviously not a fan.
Old Jul 31, 2005 | 05:16 AM
Not in the front seats, and depending how dynamic that set is wont be a huge issue in the back seat- thats actuaslly whats nice about using a 4ch for a whole system- typically the output for both front/subs is a balanced one.
Thats the effect of car audio subs , so that you get that knock up front with the rest of your stage. How you phase, and xover that sub into your system will affect how it blends up front.
If you think it'll sound weird, then obviously you dont realize that Sound Quality competition vehicles are designed this way, you actually get points taken away if a judge can hear rear fill, as it pulls the stage back.
Old Aug 1, 2005 | 10:59 AM
quiksand's Avatar
I've had rear speakers in my 97 max. In the transition from getting my system installed in my 01 Max I had the Bose system for a while. After getting my Focal components installed up front and time aligning everything it sounds great. I'll never install any speakers in the rear again.
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 7, 2015 04:20 PM
