Eclipse AV8132 indash DVD/CD no sound output??
Old Aug 5, 2005 | 03:02 PM
seventy5impala's Avatar
Hey all, i just installed this unit..... bought used.........But im having some trouble with it... Ok well it powers up, radio works and puts out sound.....but DVDs and CDs do not put out sound? like it plays the DVD on the screen and shows CD playing time, but puts out no sound???....... im pretty sure this means a defective/broken unit, since the radio puts out sound just fine....but was wondering if anyone else maybe had an idea, or something i might be missing!.........
Old Aug 5, 2005 | 03:03 PM
kpr10is's Avatar
Sure you dont have your power antenna wire switched with your remote turn on by mistake?
i.e. the usually thin blue wires coming from the amp should go to the blue/white from the deck, not the blue.
Old Aug 5, 2005 | 04:01 PM
Not sure how that might effect it, but i checked and all is good..... each wire is connected right..... but as i say the radio works fine..... just the sound output on DVDs and CDs does not work............... what about ifi was too connect a digital audio out cable too the back of the unit and connect it too the brain? perhaps maybe, errr i dunno.....
Old Aug 5, 2005 | 04:18 PM
kpr10is's Avatar
That might affect it because your power antenna gives 12v output from the deck only when the radio is on, whereas your power antenna (blue/white) gives output when the deck itself is on, on any source, so that your amps are on whenever the deck is on.
Just check and see if the amps are actually lit up/turned on when you have a dvd or cd in.
Old Aug 5, 2005 | 04:23 PM
Ahhh i see what your sayin now.....but i went andchecked, yes the amps are on with a CD in......
Old Aug 5, 2005 | 04:26 PM
kpr10is's Avatar
Only thing you can do is start narrowing down now, i.e. put a CD in and test your RCAs at the amps to see if theyre getting any signal. A multimeter is your best friend.
Old Jul 20, 2009 | 09:07 PM
santiagod's Avatar
HI, I have been endlessly trying to find a forum or info with the EXACT same issue i'm having on the same Eclipse AV 8132 unit. I was just wondering how did you fix that prob because I can't seem to understand what the prob is.
Thanks bro
David
Mahmuth
Aug 16, 2024 08:23 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
