? concerning battery relocation.
Old Aug 19, 2005 | 06:58 AM
maxmale's Avatar
can i just use the power wire i had installed for my stereo as the wire to hook my battery up in the trunk, it is 4 gauge wire good quality copper.
also i am assuming i would just ground the neg cable under the hood to the chassis and then reground the battery to something in the trunk.
ne input on this?
Old Aug 19, 2005 | 07:13 AM
Wakkus_Maximus's Avatar
Is there an advantage of having the battery in the trunk? If the car is FWD and you move more weight from the front to the back, won't it make your MAX pull instead of push? I'm just using logic here, but won't that make it slower?
Old Aug 19, 2005 | 09:58 AM
jigga123's Avatar
Yes, you can do that. I assume its for your stereo and if it is get a isolator. It'll make things easier.
Old Aug 19, 2005 | 01:30 PM
maxmale's Avatar
ummm, whats an isolator?
Old Aug 19, 2005 | 04:04 PM
jigga123's Avatar
http://www.bcae1.com/battiso.htm, this could prolly explain it better than I ever could. It basically seperates your starting battery from your stereo battery.
Old Aug 19, 2005 | 04:12 PM
DeusExMaxima's Avatar
The battery in the trunk actually improves the handling of a car since it balances the weight more evenly. I think 4 gauge wire is ok. I am considering this mod for the handling benefit.
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
markevans999
Sep 10, 2015 04:29 PM
