Rewiring bose system, hard or not?
Old Aug 21, 2005 | 02:53 PM
gtmuggs's Avatar
Im considering replacing my stock Bose system in my 4thGen Max im wondering how hard it is to do so the guys thats already done this mod can you let me know. and are there any special parts i need to use, also can you use the stock wires to wire the new speakers?
Old Aug 21, 2005 | 04:22 PM
djfrestyl's Avatar
Suspension Yoda
Why would you replace the Bose system in your car with another Bose system?
Just go aftermarket and be happier.
Old Aug 21, 2005 | 06:16 PM
rmh3093's Avatar
Only gentoo powered Maxima!
having bose makes things a pain in the ***, but as long as you are up for its worth replacing every inch of the old system
Old Aug 21, 2005 | 06:44 PM
gtmuggs's Avatar
thats my plans i would never put another bose system in my car, i want to go fully aftermarket everything will be replaced even the wiring if needed, i already have the alpine head unit and the focal door speakers but not sure if i will use the focals.
Old Aug 21, 2005 | 07:19 PM
djfrestyl's Avatar
Suspension Yoda
Well then, it's not that hard just time consuming - lots of speaker wire to run.
And if u go amps, then you've gotta run power wire too.
Old Oct 5, 2005 | 06:23 AM
impliedparadox's Avatar
I am thinking of doing the same thing. Any tips on how/where to run the wires?
Old Oct 5, 2005 | 03:46 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
if your slick and not above using the factory wires these are the steps.
Remove your radio. Put in the wiring kit.
Open the doors, remove the amps. The wires that are exposed there run to the tweeter in the door. These run to the back of the radio (IE Now your wiring harness). Extend those wires in the door to your new speakers in the door.
To get power to these wires you run all amplifier wire to the area behind your headunit and plug in behind the radio to the factory wires. So in a sense
Amp------Factory wires behind Radio----Through wires in door---FACTORY AMPLIFIER Eliminated so signal is straight to speakers now
Old Oct 5, 2005 | 03:50 PM
Chocolate_Boi_1Der
should be able to tell from these.
Old Oct 5, 2005 | 03:51 PM
Chocolate_Boi_1Der
I used the plastic mounting cup until i did a 1.5 inch spacer (dual 3/4 inch mdf rings, with deadener inbetween then siliconed to the door) which the speakers mounted to. My wires ran into the xover then out to the factor location for the wiring. I have some updated pics if you need a bigger one.
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
Sir Tilus
Mar 22, 2016 01:49 PM
RWCreative
Sep 21, 2015 11:01 AM
A32goldylocks
Sep 2, 2015 06:39 AM
