Hey all.....im having some tweeter issues...... both my front tweeters cut out when im playin rock at high volumes......its pretty annoying cause they play such a key part in the sound...... it doesnt do it with rap or anything else that ive noticed...but itll play fine for a little bit, then they cut off(the tweeters that is) the 6.5s still work fine(orion p6.2 component set) in order to get them back i gotta turn the volume way down....then when i turn it back up they are back....but will cut out again at high volume............ any ideas whats wrong???? bad tweeters maybe? can u replace just the tweeters from a component set and use the same crossovers???
anthony
anthony
thats tweeter protection...turn the eq down, volume down, or gains down, or all 3.
if your xover's didnt have this you would have no tweets right now.
if your xover's didnt have this you would have no tweets right now.lol ill dig around in the EQ...any idea which frequincies it might be on the 13 band eq? but my gains are a little over 1/4 up... and the volume bah, that cant go anywhere
thanks for the info by the way...u gonna be at the next max out? would like to hear your car
turn off all loudness, SLA, and put the eq from roughly 5k and up on flat...play it at the same volume and let us know how it sounds. if its not loud enough try boosting some of the frequencies from roughly 5k to +1 only. maybe try a boost at 10k. i honestly dont know which frequencies the 13 band eq controls on that unit.
true thanks...i know for a fact loudness is off, but sla i think is up 1 or 2 notches, ill look into it tho! and let ya know how it goes.... buttt u seem to know this unit better than i do lol
yeah id try turning the sla off and leave the eq settings if you are playing it at volume 30-35. the sla is basically another volume **** so chances are you are clipping the amp.
True thanks Slick.....turning the sla down too 0 helped and i dont notice them cutting out anymore! that was buggin the crap outta me......
