My screen has lines from dvd player..too much voltage or current??
Old Aug 28, 2005 | 04:16 PM
ImmaSquashYou's Avatar
since i got this new DVD player that is now 12v, i don't need my inverter nemore for my reg dvd player that WAS in my car. it's much easier now. but i now get lines on the screen through that dvd player. i believe its getting distorted through the power wire. its connected to the same wire as my head unit and flip out power source. I believe i get lines because there's too much voltage going through the wire i believe?? if so, what ohm resistor should i get....or is it too much current that's causing this since i don't think that 2-3 votls would cause this. how can i fix this, does neone know??
Old Aug 28, 2005 | 04:51 PM
djfrestyl's Avatar
Suspension Yoda
you're getting engine interference through the thin tiny power wire.
Microvision? I had the same thing in mine.
I never solved it so I don't have any suggestions, but try another source or a shielded RCA.
Old Aug 29, 2005 | 06:18 PM
bump??? neone know how to fix this problem?>
Old Aug 30, 2005 | 06:13 AM
erty67's Avatar
Decal Specialist
double check your ground to the screen and the dvd player. Mine did this when the DVD player had a loose ground.
Old Aug 30, 2005 | 03:19 PM
Unibomber's Avatar
i use to get the lines on my clarion flipout when i ran the xbox from an inverter..it ended up being the ground.
Old Aug 30, 2005 | 03:39 PM
GodsmackMAX's Avatar
yah check the ground. my ps2 and microvision does the exact thing u describe but I really never pay attention to it. It's really really faint on mine though so its not a big deal to me. Nobody has ever noticed it except me.
AaronL
Nov 15, 2020 11:52 AM
Fbana41
Aug 29, 2016 12:18 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
