What is a good amp to power 2 Solo Baric L5's
Old Sep 1, 2005 | 08:58 AM
Rick James's Avatar
I was using my friends zapco 1100 watt.
I want something similar.
Old Sep 1, 2005 | 09:09 AM
filtor1's Avatar
We need a budget. I personally have marked out to Diamond Audio's amps. I don't know of any other company with the nuts to offer a lifetime warranty. I personally have the D61500.1. 0 issues. You will pay more b/c you would have to buy it from an authorized dealer. Worth every penny. It would run you between $800-$900 depending on the dealer. Another optiojn is the D6100.1. A bit cheaper and will still wake every bit of those L5's up.
Old Sep 1, 2005 | 09:28 AM
MannyNJ2k2max's Avatar
Arc xxk2500(class a/b) or xxk1500d (class T)
or throw a Kicker SX1250.1 on it
Old Sep 1, 2005 | 09:33 AM
filtor1's Avatar
Two more great companies.
Old Sep 1, 2005 | 11:50 AM
Rick James's Avatar
Thanks for the quick replies.
I can now start doing research on these amps.
As for a budget i think i wanna stay under $500.
Is the JL 500.1 any good?
Old Sep 1, 2005 | 01:17 PM
lol , you originally said 'comparable'.....That Zap is +1000rms rated class a/b...That JL is half that power. IMO if you want killer performance from those L5's you need more juice.
In that budget....
How about the Arc Kar 900.1...
450x1 @4 ohms, 750x1 @2 ohms, & 900x1 @1 ohms
http://www.arcaudio.com/arc-05/amplifiers/kar_9001.htm
I recommend Arc, because Arc chief engineer/designer is Rob Zef (the Z in Zapco) You asked for comparable to the Zap Reference, heres comparable build/performance/design amplifier substantially less.
Old Sep 1, 2005 | 01:21 PM
Polecat's Avatar
first, what ohm woofers do you haver? This will help find an amp that will do max power into the porper ohm. Like a Kicker KX12001 does max into a 1 ohm load, but if you have two DVC 2's, it won't work, etc
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
melteye
May 16, 2016 12:02 AM
vybz05
Dec 10, 2015 07:38 PM
maxinout93
Oct 27, 2015 01:29 PM
homeyclaus
Sep 3, 2015 06:15 PM
