wiring subs question
Old Sep 22, 2005 | 06:08 AM
sureal00's Avatar
would anyone of the below wiring setups run better or more stable than the other ?
Would wiring 2 subs that are 2 ohm down to 1 ohm (parallel ) run better or more stable than running 2 4ohm dvc subs wired to 1 ohm (parallel )
This is my amp specs
Hifonics BX 1205D Brutus Series Monoblock Amplifier
Power Amp Category/Type: Mono Block
4-Ohm Power Rating: 1x450
2-Ohm Power Rating: 1x900
1-Ohm 1200-Watt x 1 RMS
SUBS i have
Kicker Comp VR 01C12VR4
12 inch speaker
Dual 4-ohm voice coils for wiring flexibility
Frequency response 25-500 Hz
Power range 50-400 watts RMS (200 watts RMS per coil)
Peak power handling 800 watts
Sensitivity 86.7 dB SPL
Old Sep 22, 2005 | 06:42 AM
Batxel's Avatar
blah
the "stability" of your wiring setup is dependent on what the amp is designed for. Just wire it up for the impedence that the amp puts out the most power.
Old Sep 22, 2005 | 07:42 AM
filtor1's Avatar
http://elliottelectronics.com/Spkwiringset.htm
Lookie..... Go with the 1 ohm configuration.
The Frye
Sep 2, 2021 11:03 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
