Big 3 done, dramatic diffrence in system??
Old Oct 3, 2005 | 07:32 PM
seventy5impala's Avatar
So i finally got around to doing the big 3.....and i dunno if its cause i had to reset my radio settings or its the big 3(which i think cause all my settings are less than they were or not completly adjusted) but my system is like WAY louder/better/clearer even than it was... for example i used to listen at volume 30(that being the max id go) and now at volume 25(is my max now) its lounder than it ever was at 30, bass and highs but clear......is this all to thanks too the big 3 upgrade? if so i just gotta say damn. everyone should do this.......... makes me enjoy the system even more again......
Old Oct 3, 2005 | 07:57 PM
SC2K1's Avatar
The big three helped my system. The sound is cleaner now than it was before.
Old Oct 3, 2005 | 08:27 PM
slickrick's Avatar
i need to do this asap.
Old Oct 3, 2005 | 09:41 PM
Maximeltman's Avatar
hey seventy what gauge wire you use? I used 4 gauge, but maybe I oughta try 0ga...I need a ho alt....I need a ho! lol!
Old Oct 4, 2005 | 04:03 AM
i used 4 guage also only place i saw where 0 might be needed was at the battery, buti figured just use the stock batt ground thats there and add another 4 guage too it, would be plenty.... i also have a 140 amp alternator, like 30 or so bigger than stock
Old Oct 4, 2005 | 06:40 AM
MannyNJ2k2max's Avatar
made a big difference in my dimming, music is much more dynamic and strong...hence i feel my amps are drawing power better
Old Oct 4, 2005 | 08:04 AM
maxgtr2000's Avatar
KH3 by popular demand
Big 3 is tha bomb.
Old Aug 26, 2007 | 11:46 AM
redls1's Avatar
MAXIN' ON
Ive grounded everything else and then some, some the question is ? Is doing the positive wire on the alt to the battery really worth it. Seems a little difficult to get to. I also have used up all my conections and only have 1 8 gauge slot open. Will that be enough?
Old Aug 26, 2007 | 02:33 PM
filtor1's Avatar
It did wonders for me.
Old Aug 26, 2007 | 03:59 PM
mendon99's Avatar
tastey wheat
didnt make a noticeable difference for me. Then again, I haven't had a sub setup in my car for almost 6 months, just a highs amp - and i did it a few months ago. I guess time will tell (as soon as i get something new)...
this is a pretty old thread.
Old Aug 26, 2007 | 04:00 PM
filtor1's Avatar
Kudos for searching though.
Old Aug 26, 2007 | 06:15 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Yes, when was easy work ever really worth it?
Old Aug 27, 2007 | 03:29 PM
russpimpin's Avatar
might be a silly question and i may get mocked but hey closed mouths don't get fed. what is the big 3?
Old Aug 27, 2007 | 03:45 PM
Pearl96Max's Avatar
3 various ground points under your hood. Seems to improve overall performance by changing these wires out to better ones.
The only silly/stupid questions are those left unasked.
Old Aug 27, 2007 | 08:21 PM
JEXTEL's Avatar
I want to do but will it good to add 4 gauge? like leave the stock wires and add the 4 guage so it will be 2 runs because 0 gauge cost alot and I have tons of 4 guage...
Old Aug 27, 2007 | 08:26 PM
filtor1's Avatar
Originally Posted by JEXTEL
I want to do but will it good to add 4 gauge? like leave the stock wires and add the 4 guage so it will be 2 runs because 0 cost alot and I have tons of 4 guage...
That will work as well.
Old Aug 27, 2007 | 08:44 PM
JEXTEL's Avatar
cool what yall guys use to crimp 4-0 guage wires? besides a vice
Old Aug 27, 2007 | 08:51 PM
filtor1's Avatar
If you don't want to buy a vice or large crimping tool, I find that a hammer and a concrete floor do the trick.
slickrick's Avatar
your teeth man up son
Old Aug 27, 2007 | 09:24 PM
KsuMax's Avatar
Cheesing away...
when I put my y yipe in a long time ago
Old Aug 28, 2007 | 12:10 PM
JEXTEL's Avatar
I did that and all of them came loose at some point
Old Aug 28, 2007 | 12:42 PM
filtor1's Avatar
Don't know what you did different than me. I haven't had one comm loose yet.
Old Aug 29, 2007 | 02:09 PM
ThurzNite's Avatar
Would you mind if I used any of your leftover 4ga?
Jae
Old Aug 29, 2007 | 02:42 PM
Fast1one's Avatar
Use a mallet, hammer one side FIRST, then turn it on its side, and hammer it a little until one of the flaps that you hammered down slides under the other...
Turn it around and hammer until you can''t anymore
Old Aug 29, 2007 | 03:19 PM
DcMaN's Avatar
i did 0 gauge positive input to distro, 0 gauge ground to chassis of car from batt terminal, upgraded the alt wire with 4gauge, also upgraded the wire coming from the fuse box to 4 gauge instead of dual 8gauge from factory, upgraded the starter solenoid wire, and also upgraded the factory ground to 4gauge wire. The dimming in my car is minimal, but you must remember most dimming is due to the ohm load of the sub amp. Usually 1-2 ohms will draw the most current, and 4 ohms usually doesnt put as much strain on the cars electrical system. Also depending on the design of the internal powersupply of the amp the certain type whether it may be Class A, A/B, or Class D may draw more or less. Usually Class D amps carry a good power to efficiency ratio.
Old Aug 29, 2007 | 03:49 PM
Fast1one's Avatar
The ohm load has nothing to do with it, i can have a 50 watt Class D amp running at 1 ohm with minimal issues...
You got most of the rest right, all depends on the power...
Old Aug 29, 2007 | 04:45 PM
filtor1's Avatar
Please slap the person that told you that ohms are the reason for dimming. Current draw is the reason for dimming.
Old Aug 29, 2007 | 06:21 PM
Pearl96Max's Avatar
TECHNICALLY it *could* affect it, but only because the amp is being driven harder - thus more current draw. But in the real world, no impedance has Absolutely Nothing to do with strain on the electrical.
Old Aug 30, 2007 | 11:37 AM
DcMaN's Avatar
what if the amp does all ohm loads at the same power. Say the amp does 1-4 ohms @ 1000 rms. Your basically saying if you put it at 1 ohm the lights will dim the same amount as 4 ohms right ? Maybe its just me, or maybe it depends on the type of the amp, but ive definatly noticed more dimming at a lower ohm load than at a higher impediance. But like i said maybe its just me.
Old Aug 31, 2007 | 07:30 AM
Prophecy99's Avatar
.......so a hyper grounding kit helps audio too? nice
sitting on my desk to be installed asap
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
