firewall grommet
Old Oct 4, 2005 | 10:00 AM
Weimar Ben's Avatar
Helicopters! Money!!!
firewall grommet
I have a 97 max w/bose. Where the hell can I put a power wire through the firewall? I saw a little hole behind the ECU, but there doesn't seem to be hole in the firewall there. Where are people putting the power wire through the firewall for amp?
Old Oct 4, 2005 | 10:17 AM
Weimar Ben's Avatar
There's nothing in the FAQ about this and I didn't see anything in the FSM.
Old Oct 4, 2005 | 10:57 AM
mtrai760's Avatar
'Trynna' is not a word
Below the fuel filter about 3 inches there is a rubber grommet that you can remove to route wires through to the cabin. Ive always run mine under the car and back to the trunk. There is a grommet at the back of the wheel well you can remove to run the wire in that way.
Old Oct 4, 2005 | 11:08 AM
Weimar Ben's Avatar
Soundsl like a PITA to get to. Well, I think I'll just wait till I do my 3.5 swap and run the wire then.
Old Oct 4, 2005 | 11:41 AM
mtrai760's Avatar
Actually its pretty easy to get to.
Old Oct 4, 2005 | 01:10 PM
kpr10is's Avatar
I really need to take a pic of where I drilled my firewall so this question stops popping up every few days. Theres no need to run your wiring under the car.
Old Oct 4, 2005 | 03:58 PM
djfrestyl's Avatar
Suspension Yoda
Blackbird are you auto or manual?
Old Oct 4, 2005 | 04:00 PM
Weimar Ben's Avatar
It's a manual
Old Oct 4, 2005 | 06:14 PM
mingo's Avatar
you can drill a hole next to the clutch master cylinder.
or feed it through the plate that covers where the auto tranny shift cable was suppose to go, you can fit at least 5 zero gauge cables through that location if you removed the plate.. (at least on 5th gens)
fastcarny
Oct 12, 2015 07:06 AM
schmellyfart
Sep 25, 2015 04:47 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
