Active soundstage?
Old Oct 6, 2005 | 11:17 AM
nismos14's Avatar
§è~® f®ÈÄk
Active soundstage?
So can someone define what exactly this is to me? I thought it was having you're low's on one amplifier, you're mid's on another, and you're high's on another (3 different amps) is this correct?
Old Oct 6, 2005 | 11:34 AM
505max94se's Avatar
that's mostly correct....
It means to use an active (typically powered) x-over before the amp(s) instead of a passive x-over after the amp(s).
Old Oct 6, 2005 | 11:37 AM
Pearl96Max's Avatar
I tend to get a bit irritable
It doesnt have to be 3 seperate amps per say, but 6 channels. Typically youll be bandpassing or "trapping" each set.
Once you go active, I promise youll never go back to passives.
Old Oct 6, 2005 | 11:43 AM
505max94se's Avatar
You also could use a 4 channel amp for a 2-way active front stage (mids needs alot more power than tweets)
Old Oct 6, 2005 | 11:47 AM
nismos14's Avatar
§è~® f®ÈÄk
Well I've been thinking about getting rid of the coax's in the back as u know. Maybe we'll throw in some Rainbow seperates at some point too
NissanNismoZ
Sep 12, 2015 07:30 AM
rbaker100
Aug 28, 2015 08:11 PM
Slamrod
Aug 10, 2015 12:33 PM
ramtin325i
Aug 8, 2015 05:13 PM
Maxima95GLE
Dec 7, 2000 11:02 AM
