Help with Car Audio
Old Oct 12, 2005 | 08:12 PM
  #41
TriniRicanPapi's Avatar
i really appreciate everyones help i just want to know exactly what i have to tell tweeter to do to get it right this time.
Old Oct 12, 2005 | 08:17 PM
  #42
so basically to sum up for now what i have to do is upgrade my big 3 to 0 guage and also upgrade the power wire running back to my amps and caps to 0 guage as well? is changing the battery necessary right now or should i just do the wiring first?
Old Oct 12, 2005 | 08:21 PM
  #43
Matt93SE's Avatar
STFU n00b!
If you've got a good battery now, it shouldn't be required..
also when you upgrade the cabling, go to a welding supply store or an industrial cable supplier... I paid $1.10 a foot for my 1/0 power and ground cables from a place called Industrial Cable & Supply in Tulsa, OK.
don't let tweeter charge you $15 a foot for their stuff. just insane markup and the quality of wire is the same.
Old Oct 12, 2005 | 08:35 PM
  #44
so i wouldn't need to upgrade the ground going from the amp to the trunk? if so how would i go about getting the 0 guage wire in the hole for the ground in the amp?
Old Oct 12, 2005 | 09:04 PM
  #45
filtor1's Avatar
Not if it is 4gauge. If it is 8gauge or lower, def upgrade to 4. A good ground is just as important as the power that feeds it.
Old Oct 13, 2005 | 02:12 PM
  #46
i talked to someone over at Trenton Generator and Starter and they don't recommend getting an optima battery, i'm not sure why. does anyone else care to comment on whether its better to have an optima or not?
Old Oct 13, 2005 | 05:07 PM
  #47
filtor1's Avatar
Not sure why he would tell you that. I have never heard the first negative comment since I started using them several years back. I have never needed to use a warranty either. Not once.
Maybe he just wanted you to buy a new alternator? I would love to hear his reasoning though if you go back.
Old Oct 13, 2005 | 05:09 PM
  #48
AscendantMax's Avatar
yep, he probably wanted your business instead of you getting an optima.
Old Oct 13, 2005 | 10:04 PM
  #49
actually he couldn't offer me any services. he said he wouldn't recommend changing the alternator or upgrading the wiring because it may damage the rectifier
Old Oct 13, 2005 | 10:08 PM
  #50
well i guess he has no experience in car audio. you can't expect to run a high power system using tiny wires...
  #51
but i think i figured out what the problem was. i mean he did move around the battery today and ever since i've been blasting my bass as hard as i can and no clipping. i guess that connection to the battery was either a little loose or that oxidization on the terminals was causing a bad connection. but in any case it seems that the problem is solved hopefully i can get that connection tightened up. is there any way i can protect those terminals from getting that oxidization build-up?
Old Oct 13, 2005 | 10:11 PM
  #52
yeah, just apply a thin layer of dielectric grease onto the terminal posts. you can get them at any auto parts store.
Old Oct 13, 2005 | 10:20 PM
  #53
they only make the red top battery for the max right?
Old Oct 13, 2005 | 10:35 PM
  #54
slickrick's Avatar
you can get a yellow top for the max also...
Old Oct 13, 2005 | 10:36 PM
  #55
wut model? i was checkin at autozone and they didn't show one
Old Oct 14, 2005 | 07:51 AM
  #56
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
just get the standard size. theyll even swap the battery out for you, make em work. I have a yellow top in mine.
Old Nov 17, 2005 | 08:45 AM
  #57
I have a problem, I had this guy upgrade my big three and he grounded my battery to both the chassis and the engine block, isn't it supposed to be from the battery to the chassis and then from the chassis to the engine block or does that not make a difference?
Old Dec 16, 2005 | 10:34 AM
  #58
Update
Hey Everyone,
I updated my big three to 0 guage, ran 0 guage going back, and got an optima yellow top battery. It helped but still not good enough, amp still cutting out on high volumes. I guess this means my only option would be to upgrade the alternator. Anyone on here a dealer that can offer me a good deal on an alternator?
Old Dec 16, 2005 | 01:26 PM
  #59
nismos14's Avatar
§è~® f®ÈÄk
I would venture to say that the amp might be the problem, not the alternator. If the alternator was the problem the car itself would have major problems too, i would think. If it is the stock alternator then it may need replaced with a heavier duty one.
Old Dec 16, 2005 | 04:31 PM
  #60
KCMaxima98's Avatar
I run the two amps in my sig off of a single 4 gauge wire....both older RF's that are supposedly power hungry. They both share a 60 amp fuse at the battery and it has never blown! They are both rated at 60 amps each and I'm running the 800.2 at 4 ohm mono and the punch at 2 ohm stereo. They are pretty conservitavely rated at 1200 wrms at this configuration but at full tilt my lights barely dim at all. I have no big 3 or caps or any of that. Either these JL's are really power hungry I would suspect that there is a problem with your install. Maybe your alternator is about to give up the ghost?
Old Dec 16, 2005 | 07:45 PM
  #61
i doubt there's something's wrong with the install, its been checked over two times after the install, might be the amp, but not really sure
Old Dec 16, 2005 | 07:57 PM
  #62
Supermax95's Avatar
i have three 1000 watt amps running off a 1 farad cap and 4 guage wire....no problems here
Old Dec 16, 2005 | 09:05 PM
  #63
Pearl96Max's Avatar
I tend to get a bit irritable
And what kind of amps might these be?
Old Dec 16, 2005 | 10:03 PM
  #64
KCMaxima98's Avatar
Is that 3000 continuous watts? If so, you need 0/1 gauge....what amps do you have???
Old Dec 17, 2005 | 11:57 AM
  #65
nismos14's Avatar
§è~® f®ÈÄk
When was the last time your battery was replaced?
Old Dec 17, 2005 | 01:05 PM
  #66
any more ideas on what my problem might be? I have big three 0 guage, 0 guage running back, a new Optima Yellow Top, and two 1 farad caps both connected to the 1000/1.
Old Dec 17, 2005 | 01:23 PM
  #67
nismos14's Avatar
§è~® f®ÈÄk
The amp.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Aug 12, 2015 06:39 AM
Slamrod
Aug 10, 2015 12:33 PM
MikesChevelle
Aug 9, 2015 11:50 AM
